Certified Pre-Owned
General questions for setting cam timing
Hi all:
I have a '84 3.2 rebuild that is coming together with Mahle 10.3:1 Ps and Cs using a 964 cam grind, the cam being spec'd to 1.26 mm on overlap for setup (all Motronic stuff). Questions: 1) When you set your cam timing, how tight do you shoot for getting the timing chains when doing the process? I have the Stomski mechanical tensioners that I plan to use for setting the timing and will then swap out with the factory pressure fed tensioners when complete. 2) What sort of variance in mm is acceptable between the 1-3 and 4-6 cam? I set cam timing on a 911 engine before but it has been years... Obviously having them the same is ideal but I don't see 1.26 vs. 1.26 L to R bank as realistic. Thanks for your input. BG
'84 Carrera Coupe |
I was able to get mine timed to 4.83 & 4.84 just recently. I noticed I would lose a little advance if I didn't hold it tight with the sprocket tool. I suppose there is some play in the pins. But it wasn't too difficult to get right.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Once the bolts are tight nothing is going to change
I do like Steve’s video on setting cam timing. He has a way I never thought of doing for nearly 40 years but it works great Bruce |
Interesting.
Sent from my iPhone using Tapatalk |
Great video by Steven
356 guy
Hey Guys,
I'm sure that Steve (Steven) is amazing and well known; but for those of us new to Pelican, it sure would help if you provided a video link so that we too could learn from his knowledge. John |
Hi, Here’s a great set of videos from Steven ![]() One important thing to keep in mind regarding the method used in the video for cam timing is: - when used for camshafts with high overlap all rockers must be installed so that the camshaft does not move during the timing procedure. https://www.stomskiracing.com/pages/instructions Sent from my iPhone using Tapatalk Last edited by Classic 911; 01-22-2024 at 01:03 AM.. |
You can achieve values "in-between" two holes if you do end up landing somewhere, where the pin does not fit.
If you need to slightly more retard the cam, turn the motor until you have lash, loosen the cam sprocket bolt, and turn the motor CW until the rocker is starting to ride on the cam. This will take up the slop in the pin hole and push the cam slightly to retard. Torque down the cam nut. If you need slightly more advance, do the same thing but turn the motor CCW. I've found through timing my race cams with degree wheel, each hole is worth ~2.7 degrees of lobe angle (ie: intake lobe is at 105, advance cam 1 hole and ya end up at ~102.3). |
356 guy
Thanks Classic911!
John |
