| Registered |  Intermediate Shaft Not Enough Backlash Remedy
			What is the solution if the backlash is too little? We are rebuilding our 1970 914-6 (aka 1969 911T) engine. Our original intermediate shaft was out of spec. We replaced it with a new one from Porsche. Crank refurbished by a well known machine shop with excellent reputation. 0 marks on crank gear and intermediate shaft. There is no perceptible backlash watching, listening, feeling. Best case with dial indicator is it .01mm, but it is hard to be sure I'm not moving the crank to get that. So we're under the published spec. What can you do about it? | ||
|  01-26-2024, 06:00 PM |
| PCA Member since 1988 |
			As long as there's no interference or binding between the gears, I'd run it.
				__________________ 1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! | ||
|  01-26-2024, 11:58 PM |
| Registered Join Date: Apr 2012
			I'm no expert, but... Make sure to check your case to see if it's a "0" or "1". Gears can be mixed to provide proper backlash. Also, make sure your bearings are seated when measuring. This thread might be helpful to you: https://forums.pelicanparts.com/911-engine-rebuilding-forum/1012916-intermediate-shaft-assembly-question.html#post10248955 Quote:
				__________________ Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair | ||
|  01-27-2024, 10:51 AM |
| Tags |
| ims , intermediate shaft , intermediate shaft gears |
