-   -   Intermediate shaft surface question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1155809-intermediate-shaft-surface-question.html)
zztot 02-04-2024 07:18 PM
I am cleaning up parts for a guy to build my 2.0 engine. Today I did intermediate shaft and two bearing surfaces appear to be a little marred. Part has the look but doesn’t snag my finger nail. Have not asked him but trying to anticipate what needs to be done.
Thanks for input.
http://forums.pelicanparts.com/uploa...1707102917.jpg
http://forums.pelicanparts.com/uploa...1707103075.jpg
porschedude996 02-05-2024 12:14 PM
Have it polished like they do to a crankshaft.
zztot 02-08-2024 08:25 AM
Additional question
Silly questions
1. Do gears need to be removed for polishing shaft?
2. Typical cost to polish ?
porschedude996 02-08-2024 10:03 AM
Originally Posted by zztot (Post 12189616)
Silly questions
The shaft in your pictures doesn’t look great. My new intermediate shaft bearing diameters were about the same as my old shaft. I bought a IS complete with gears which was special order and no returns. I might have been ok by just replacing the one chipped aluminum gear.
I think the gears could stay on, providing it is washed well after polishing. I’m not sure on the cost for this, but it couldn’t be much. My crankshaft was $90 to remove oil galley plugs and polish.
stownsen914 02-08-2024 01:55 PM
Take a good look at the aluminum gear teeth. They can be pitted as an early indicator it's time for replacement. You don't want one of those failing.
I ask because if you are removing that anyway, at least one of the small gears comes off too if memory serves.
zztot 02-08-2024 02:16 PM
More
Gears appear to be pretty nice…….but not shaft.
Appreciate the input.
draw 02-08-2024 03:34 PM
Try buffing it out with a red/maroon scotch brite pad. Or start with a gray pad if you want to be a little less agressive...
ryanrobert 02-08-2024 07:10 PM
Have it cleaned and polished like they do to a normal crank shaft pulley
