Intermediate shaft surface question
I am cleaning up parts for a guy to build my 2.0 engine. Today I did intermediate shaft and two bearing surfaces appear to be a little marred. Part has the look but doesn’t snag my finger nail. Have not asked him but trying to anticipate what needs to be done.
Thanks for input. ![]()
TOT |
Have it polished like they do to a crankshaft.
Additional question
Silly questions
1. Do gears need to be removed for polishing shaft? 2. Typical cost to polish ? Thanks
TOT |
I think the gears could stay on, providing it is washed well after polishing. I’m not sure on the cost for this, but it couldn’t be much. My crankshaft was $90 to remove oil galley plugs and polish. Last edited by porschedude996; 02-08-2024 at 10:10 AM.. |
It's a 914 ...
Take a good look at the aluminum gear teeth. They can be pitted as an early indicator it's time for replacement. You don't want one of those failing.
I ask because if you are removing that anyway, at least one of the small gears comes off too if memory serves. |
More
Gears appear to be pretty nice…….but not shaft.
Appreciate the input.
TOT |
Try buffing it out with a red/maroon scotch brite pad. Or start with a gray pad if you want to be a little less agressive...
Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair 2006 Carrera S - Sold |
Have it cleaned and polished like they do to a normal crank shaft pulley
