JLN JLN is offline
911SC 3.0 - New Camshafts
Hi
We live in Europe. The camshafts are damaged on 911SC, 3.0.
We want to buy new ones, and Porsche OEMs are too expensive.
Which suppliers are available for high quality standard OEM camshafts:
Partsworks.de, Rosepassion, Design 911 ?
Is the quality of the camshafts the same from all of them?
Trim camshafts are easy to find. Not so easy to find almost standard
Old 02-18-2024, 07:11 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by JLN View Post
Hi
We live in Europe. 911SE, 3.0 camshafts are really damaged. .
We want to buy new ones. Porsche OEMs are too expensive.
Is the camshafts quality the same from all ? Trim-camshafts are easy to find.
Not so easy with standard? 👍
Having your factory cams refinished is generally an option.
If they are really nackered you can generally source good used SC.
Remember that 3.2 Carrera cams have the same profile.
If neither of those options appeals to you, John at DRC is our go-to guy.
"John @ DR Cams"
We may have a fresh set on the shelf.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-18-2024, 10:33 AM
JLN JLN is offline
Thanks for the private messenger
We ordered camshafts from Catcams ( 5200109 ). These are high quality, are mild but give a little more than the OEM.
Has anyone tried these camshafts in their 911SC 3.0 ?
Old 02-20-2024, 11:37 PM
PCA Member since 1988
If you have a choice of whether the cams use the large nuts or bolts to hold on the sprockets, go with bolts. Then you don't need the big ass crow-foot wrench to install, remove, or time them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-21-2024, 12:03 AM
JLN JLN is offline
Thumbs up
Ordered Catcams 5200109: Changing at the same time to euro 204 piston.
The data shows that Catcams are pretty mild camshafts.
Has anyone tried this or anyone with similar data? Experiences?
Old 02-22-2024, 11:53 PM
