GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
New oil fed tensioner broken?
I noticed the oil relief caps were loose prior to installation and upon touching it, it popped off! The other one is loose, but didn't seem to come off... yet?!
I thought this was supposed to be an upgrade, seems temperamental.
Thoughts?
Old 02-13-2024, 07:10 PM
Alan L's Avatar
Same thing happened to one of mine a few days ago. Just flicking the tensioner out with a screw driver and caught the cap. That was it. All over. new one on the way. They don't seem help in by much. But it is a very light spring under there. Scary to think if it came loose.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-13-2024, 09:03 PM
The ball usually ends up on the drain plug magnet, FWIW.
There's a mod outlined here somewhere where two small holes are drilled in the tensioner to add a piece of safety wire across the cage to keep it in place.
Old 02-13-2024, 11:08 PM
The pressure fed tensioners I bought in 84 have worked flawlessly. This is a new problem and I wouldn’t install them without modifications of some kind.
Old 02-14-2024, 09:01 AM
Alan L's Avatar
I made up a piece to replace that bit that fell out. From stainless, which has a coeff of expansion a bit higher than steel.
But I can't bring myself to trust it. That wire trick would help.
Alan
Old 02-14-2024, 09:50 AM
Is that ball 5 mm by any chance? I found one in the bottom of an engine last year.
Old 02-14-2024, 12:19 PM
Alan L's Avatar
I would have thought a bit smaller - maybe 3-4mm. But I can measure it in a few days. Not at home right now. But I downsized the ball slightly for my fitting - it is more complicated than it looks. I still have the original and can measure in a few days.
Alan
Old 02-14-2024, 01:30 PM
I had the same issue with a tensioner and used the wire method. Drill carefully and it should go well.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets.
Old 02-14-2024, 07:44 PM
GotaT's Avatar
Have a pic of the drill method? At this point I'm tempted to just use the original type...
Old 02-15-2024, 07:20 AM
Credit to Trackrash (Gordon) for the pic.
Old 02-15-2024, 09:20 AM
Yup, that's exactly what I did too.
Old 02-15-2024, 10:50 AM
The 5 mm ball that I found was in the sump of a CA company rebuilt engine with lots of red painted parts. Less than 200 miles on a total rebuilt mag case engine that had not been line honed or bored. Much main bearing material in the sump along with the 5 mm ball. Since I know of no ball bearings in a 911 engine, I thought that the rebuilder might have put it in the sump as a joke. No surprise since the rest of the "rebuild" was a joke.
Old 02-15-2024, 11:29 AM
Alan L's Avatar
You do hear of some horror stories.
My 930 had a 'freshly rebuilt engine' when I bought it. Turned out to be a replaced 2nd hand P&C, and RTV of every colour on every surface. Oh, and a timing lock pin in the crankcase - no extra charge.
Alan
Old 02-15-2024, 01:22 PM
Question
To original poster ….. where did you purchase tensioners?
TOT
Old 02-15-2024, 03:27 PM
Alan L's Avatar
Yep - 5.0mm. Bingo.
Alan
Old 02-18-2024, 08:20 PM
GotaT's Avatar
OEM porsche tensioners from ********az
Old 02-20-2024, 07:57 AM
Tensioner
…..Hmmm
Even more troubling
Bought a kit from vendor and wanted to determine if i needed to be concerned.
TOT
Old 02-20-2024, 08:45 AM
Alan, thanks for checking. Now I can quit wondering how a 5 mm ball wound up in the bottom of an engine.
Old 02-20-2024, 09:30 AM
