andrew15's Avatar
Worst. Rebuild. Ever.
I had my car up on the lift today and while searching for a few leaks found that for some reason the previous owner used multiple base gaskets on all cylinders. Did I say multiple? Yup, as in 5-7 copper gaskets beneath all jugs. Looks like I'm going to pull it out this fall just to find out what else was screwed up
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 06-21-2003, 06:15 PM
PRO Motorsports
Tyson Schmidt's Avatar
Probably didn't know that they make thicker base gaskets to compensate for head machining. Not supposed to stack any at all. I guess it's good that there is an outward sign of incompetence. Otherwise you'd have never known. (Trying to look on the bright side here.) Good luck.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-21-2003, 07:58 PM
