Correct intake port for a 2.4 S
I have a set of heads with 38 mm intake ports. I thought that they were supposed to be 36 mm? Can someone clarify or correct me, please?
Yes, a 2.4S should have 36mm ports.
Sent from my SM-G991U using Tapatalk |
It's a 914 ...
Sounds like someone ported yours
PCA Member since 1988
DO the intake ports have a rough-cast finish, or are they smooth?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
