It's a 914 ...
Porosity / casting imperfections in oil passages - SC case
Just curious if this is normal. I’m about to start assembling 3.5L motor and doing final prep and checks. I noticed what look like casting imperfections or porosity in the crankcase through bolt passages (or maybe oxidation damage?) . A couple pics below. These are oil passages of course, so at a minimum I’ll make sure they are clean.
Is this kind of imperfection normal? Should I be concerned? Last edited by stownsen914; 03-02-2024 at 12:56 PM.. |
It's a 914 ...
Normal.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Scott,
Just use proper (long) galley brushes to ensure the galleys are clean. Tide detergent and water works fine, then blow with plenty of high pressure air.
michaelmount Motorsports Engine Development (Retired) |
It's a 914 ...
Thank you, gentlemen. I feel better now. The case was professionally cleaned with the plugs removed, so it should be good.
