case assembly oh **** moment!
woke at 4:30 this morn- realized that when i finally got everything ready yesterday and sealed the case after reading 742 entries on the ultimate sealing thread, i had forgotten to check the lash on the intermediate shaft!!!!!
if i need to bust the case open, so be it- will spend the next two days drunk and then get to it is there any way to check/adjust/etc at this point??? |
Did you put the same gears back in it ?
You can feel it by holding the chains and working them in and out. How would you adjust it anyway, other than replacing the aluminum gear or the complete shaft?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
PCA Member since 1988
You had a bad dream. Go back to sleep.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
a few years ago when I was building my personal motor, I remember doing it to try and isolate a slight knocking sound that appeared during warm up.
ie, when cold, when started the engine was quiet... a few minutes in the slight knocking sound would appear.. then at full temp it was quiet again. Reading everything I could, I found where someone said the steel gear that drives the ims shaft, had worked loose on his crankshaft... I thought to have that checked. My machinist thought I was bonkers. I checked my ims gear lash and it was surely out of spec. Someone suggested it might have been the cause of the noise.. everything was replaced... everything was in spec. Completed the build of the motor.... (did it purely to try and fix the noise).... and the bloody thing did it still.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
It's a 914 ...
Mike - possibly side slap on a rod?
Chain fence eating turbo
HAHA, my thoughts too.......there are far worse things to worry about.....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Do what John says, pull the chain tight and try to rock the shaft back and forth with the chain, if u hear or feel any clicking your golden. Clearance only grows with temperature.
Put it back together - and it did the same thing. I gave up. That rebuild was about 15 yrs ago. The motor is fine, no oil drops anywhere, runs like a swiss watch - and the noise has gone. I guess it is in someone elses motor now. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
It's a 914 ...
Gremlins!
There is no shortage of those. Half of them have been lurking in my 930 lately. I have sent them on their way.
They will be looking for a new home - right now. Alan
It's a 914 ...
I'm rebuilding an engine now. Hopefully without gremlins.
I have redirected them - elsewhere. To those who don't pay attention to this forum and the advice. They are on their way.
Alan
