911 3.0 - Engine sound ?
We are rebuilding our 911 3.0 motor. (1979)
We are going to replace several rocker arms and the camshafts, these are damaged. The block is line drilled and there will be new bearings. It was an metallic screeching sound, increasing with revs. Same sound without fan belt, i.e. not from alternator or fan. What could this noise be coming from? Please, can anyone help us? ![]() Watch the video clip : https://www.youtube.com/shorts/ao6guBBVBvs Last edited by JLN; 03-03-2024 at 10:26 AM.. |
What did the oil look like upon disassembly?
There was some metal in the oil. The engine builder says it probably came from damaged rocker arms and the camshafts . . ? ? But he has not found a good reason for the terrible sound. The motor have normal oil pressure. He also says the oil pump is ok, but haven't opened it. Could it be faulty oil pump or something else ?
If your mechanic can’t figure out why there’s metal in your oil or why it’s making a metal on metal screeching sound better find a new mechanic. Why line bore a 3.0 unless there’s damage? What’s the mileage/history?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
PCA Member since 1988
Ditto Dpmulvan's comment. Other possible sources of noise are, the throwout bearing, timing chain and sprockets.
Your verb tense is confusing. You said the "block is line drilled." Do you mean you have already fully disassembled it, inspected it, and "line-bored" the "case"? If so, were there any signs of main bearing or rod bearing damage? How about damage or wear on the sprockets, chain, tensioners and guides?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Sorry. I'm from Europe and my English is bad
The same mechanic previously rebuilt the engine. He wants to get it right this time. . Block was inn for check. The bearings looked ok, no wear. Some deviation in roundness, the plan is now 0.25 over-dim bearings. Last edited by JLN; 03-03-2024 at 10:55 PM.. |
No problem on the language. I just need to make sure what you are saying.
![]() How many kilometers since that mechanic rebuilt your engine?
You need to search it out. A good way is to take a a couple of feet of 10mm rubber hose and hold one end to your ear. The other end is used to locate the source of the noise. Also a good way, if the noise is internal is a mechanics stethoscope.
I wouldn’t trust the same guy line boring your case who couldn’t assemble it properly in the first place. Oversized bearings aren’t cheap either.
So how did your rockers and cam get damaged? Screw up with timing right?
Why many of my rockers and camshafts were damaged is surely also a good question?
