-   -   3.2 Top End Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1158715-3-2-top-end-engine-rebuild.html)
dpom 03-11-2024 04:32 PM
Hi Folks,
I bought a 1987 Carrera two years ago. 80,000 miles, very original, very good overall condition.
But it burns oil, about 1 quart per 300 miles. Might need a top end rebuild.
Looking for some guidance on reputable shops in Southern California and ballpark prices, how long it should take, what to look for, etc. I live in Torrance, CA. Much appreciated.
http://forums.pelicanparts.com/uploa...1710203481.JPG
PeteKz 03-12-2024 12:11 AM
It shouldn't be burning oil at only 80Kmi. Are you sure it burns oil? You can lose a lot of oil through leaks too. If it doesn't leak, then, yeah, it must be going out the exhaust.
Before you start tearing it apart, get compression and/or leak down measurements.
john walker's workshop 03-12-2024 07:00 AM
Valve guides worn. Common Carrera issue.
