-   -   Dealing with broken case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1159150-dealing-broken-case.html)
RobFrost 03-20-2024 03:25 AM
Stud / bolt is broken off here on my 1970 911E case, along with a piece of the case - where one of the four bolts holds the engine to the rear bracket next to the fan pulley.
Assuming I can get the stud out, can the case be repaired, and if so, what's the best way?
https://uploads.tapatalk-cdn.com/202...83ae3170e3.jpg
Dpmulvan 03-20-2024 07:56 AM
That’s a tricky one, but yes a good welder can fill that area with tig and then you can have it drilled and tapped. I guess it depends where you live? And what resources are available.
RobFrost 03-20-2024 02:23 PM
Does it depend on the metal and whether it's a magnesium case?
Sent from my SM-G988B using Tapatalk
mepstein 03-20-2024 05:57 PM
I send my fans, transmissions, 3.2 intakes, engine cases, etc to MB911/Ben. He welds mag, aluminum, stainless, etc. if you have someone close by that is experienced in that type of repair, use them. If not, buy a 27 gallon plastic crate, wrap the case half in some HF moving blankets, zip tie the lid and send it off to Ben.
Dpmulvan 03-21-2024 08:59 AM
Magnesium can be welded no problem by a decent welder.
RobFrost 03-21-2024 09:10 AM
Just keep the fire extinguisher handy, I guess.
Dpmulvan 03-21-2024 09:24 AM
Here, watch the godfather of YouTube welding.
<iframe width="560" height="315" src="https://www.youtube.com/embed/weqTWwaaL0g?si=AEQabGwonSpIhd6L" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
pocv0 04-01-2024 09:04 AM
That engine has to be the most gunked up, dirtiest engine I've ever seen. LOL
RobFrost 04-01-2024 02:57 PM
In that case you haven't seen my 911T engine.
Billthebuilder 04-02-2024 05:57 AM
Someone had to say it
