Dealing with broken case
Stud / bolt is broken off here on my 1970 911E case, along with a piece of the case - where one of the four bolts holds the engine to the rear bracket next to the fan pulley.
Assuming I can get the stud out, can the case be repaired, and if so, what's the best way?
Old 03-20-2024, 03:25 AM
That’s a tricky one, but yes a good welder can fill that area with tig and then you can have it drilled and tapped. I guess it depends where you live? And what resources are available.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-20-2024, 07:56 AM
Does it depend on the metal and whether it's a magnesium case?
Sent from my SM-G988B using Tapatalk
Old 03-20-2024, 02:23 PM
The 9 Store
I send my fans, transmissions, 3.2 intakes, engine cases, etc to MB911/Ben. He welds mag, aluminum, stainless, etc. if you have someone close by that is experienced in that type of repair, use them. If not, buy a 27 gallon plastic crate, wrap the case half in some HF moving blankets, zip tie the lid and send it off to Ben.
All used parts sold as is.
Old 03-20-2024, 05:57 PM
Magnesium can be welded no problem by a decent welder.
Old 03-21-2024, 08:59 AM
Just keep the fire extinguisher handy, I guess.
Old 03-21-2024, 09:10 AM
Here, watch the godfather of YouTube welding.
Old 03-21-2024, 09:24 AM
That engine has to be the most gunked up, dirtiest engine I've ever seen. LOL
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 04-01-2024, 09:04 AM
In that case you haven't seen my 911T engine.
Old 04-01-2024, 02:57 PM
Someone had to say it
Old 04-02-2024, 05:57 AM
Tags
case , studs
