MFI for 1982 SC motor
I'm going to be rebuilding my 3L soon and am considering using the MFI system so that I can use "S" cams'. Is this possible or will it be cost prohibitive? What other upgrades will I need?
Old 06-20-2003, 09:19 PM
Have you considered throttle bodies with EFI? And yes it will be cost prohibitive
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-21-2003, 08:24 PM
Hilbilly Deluxe
emcon5's Avatar
Well, you would need a set of MFI throttle bodies, a MFI pump, The drivers side cam would need to be modified to drive the pump, a space cam for the pump set to deliver the fuel needs of a 3.0L engine, the heads would need to be machined to accept MFI injectors, MFI heat exchangers, and probably more stuff I am forgetting.
You probably know the stock pistons won't work.
Or you could just get a set of used Webers or new PMOs.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-21-2003, 10:17 PM
