Help Identify These Brackets and Placement
I’m towards the end of rebuilding my 3.0, and can’t find these two in my copious amount of photos. Definitely from this engine or transmission.
Old 04-15-2024, 12:07 PM
I don’t recognize either one
Bruce
Old 04-16-2024, 02:30 AM
Do you own a vw bus? That part on the right looks like a sliding door part.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-16-2024, 06:25 AM
Bruce
I think I found where the left one goes. It supports a fuel line below aux heater blower fan. It has one of those “J” shaped plastic line keepers screwed to it.
My son owned a Bay-Window and sold a few months ago. That design may have come from Porsche/VW parts closet of old design, but this one came off the car. Never had the door apart.
Judging by the secondary screw being 6mm, I’m thinking the right one must have a cushion clamp attached to it to support something. The left one had a 4mm screw that attached the line clip.
Does the Venturi have a support?
All, Thanks for putting your thinking caps on.
Old 04-16-2024, 06:55 AM
stevie 77 930's Avatar
The bracket on the left in your picture supports the fuel line clip. Mounts on the intake runner stud # 3 over the blower bracket
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-16-2024, 12:05 PM
Thanks, only one to go.
The old age is creeping in. I can recall part numbers that I used daily when I was working for an aircraft manufacturer from 1981. Before that I could take apart a Honda CB750 motorcycle to single pieces, put them in a big box, shake them up and reassemble without a photo, diagram, or any notes at the age of 14.
I guess two brackets isn’t to bad for the short term memory. Better than a Goldfish which wakes up for the first time remembering nothing ever 2 seconds.
Old 04-16-2024, 04:43 PM
I found the last one. It is part of the cruise control system. I believe it supports the pod to throttle lever.
Anyone have a photo of this area so I can see the orientation?
Old 04-17-2024, 06:43 PM
