-   -   3.8 MFI slide valve build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1162211-3-8-mfi-slide-valve-build.html)
MST0118 05-27-2024 04:49 PM
Hi All -
After more than a few years of collecting parts, I'm finally getting my 3.8 MFI engine built. I talked with Mike Bruns about the build and he agreed to take on my project so I packed my parts in a crate and sent to Florida. My intention was to build something that looks close to a 3.0 RSR engine but with more displacement.
Also, want to mention that Mike has been great to work with as this was a custom build and there were some missing parts and fabrication needed, which Mike handled with no problem as they came up. He also kept me informed with pictures throughout the process.
The engine has recently been built and we have a dyno date at JB coming up soon. I will be uploading some pictures showing the build from the early stages. I'm hoping the engine will produce good power around the RPM range with good AFRs.
Here's some of the build parts and many of you on the forum has helped with obtaining them:
964 CASE (CLEANED AND BLASTED BY EMILE AT EP9)
CASE MACHINE WORK DONE AT OLLIES
964 CAM TOWER
CUSTOM CP PISTON (FRED'S PISTON DESIGN) (11 TO 1)
MAHLE BORE IN 102MM CYLINDERS
GT3 CRANK (CROSS DRILLED AND BALANCED BY CCR)
GT3 MAIN AND ROD BEARINGS
GT3 OIL PUMP
GT3 PANKL RODS - RESIZED BY SUPERTEC WITH NEW ARP BOLTS
SUPERTEC HEAD STUDS
PAUTER ROCKER ARMS
EXTREME HEADS (45/41 PORTS - 53 INTAKE VALVE / 42.5 EXHAUST VALVE)
MFI INJECTOR BLOCKS (RETROSPORT) - MACHINED BY SUPERTEC TO MATCH PORT
SERIES 900 AMBER SHROUD (1969 STYLE)
SLIDE VALVE 46MM - BOUGHT FROM TRE/MITTELMOTOR - SUPERTEC INSPECTED
CUSTOM MFI PUMP WITH MODIFIED SPACE CAM - MFI WERKS
CUSTOM ELGIN CAM - SIMILAR TO GE80
QSC 1.75 HEADERS, Ti GT3 MUFFLER, CUSTOM EXHAUST
CLEWETT SERPENTINE BELT
MSD IGNITION
BLACK MFI HOSES - SUPERTEC
FIDANZA ALUMINUM FLYWHEEL FOR SC & ARP FLYWHEEL BOLTS
911 SC FAN AND HOUSING
SUPERTEC COLD START DEVICE
SUPERTEC RSR PUMP COVER AND BREATHER
RENNLINE VALVE COVERS
JB RACING DISTRIBUTOR
http://forums.pelicanparts.com/uploa...1716852403.jpg
MST0118 05-27-2024 04:57 PM
More Pics of the build
http://forums.pelicanparts.com/uploa...1716853949.jpg
http://forums.pelicanparts.com/uploa...1716854022.jpg
http://forums.pelicanparts.com/uploa...1716854068.jpg
http://forums.pelicanparts.com/uploa...1716854104.jpg
http://forums.pelicanparts.com/uploa...1716854146.jpg
http://forums.pelicanparts.com/uploa...1716854185.jpg
http://forums.pelicanparts.com/uploa...1716854223.jpg
Matt at Pelican Parts 05-28-2024 08:29 PM
That looks killer! I love the slide throttles!
winders 05-28-2024 08:55 PM
What are you going to rev it up to? What fuel are you going to use? What is the expected power? Race car?
Axel84 05-29-2024 12:21 AM
Jeeez - engine porn
Axel84 05-29-2024 12:22 AM
also - GT3 backbox this thing is gonna be loud lol
Classic 911 05-29-2024 11:08 AM
Real nice build [emoji106][emoji106]
JoeMag 05-30-2024 09:27 AM
Nice! What cam? Are those stainless valves or Ti?
Evan Fullerton 05-30-2024 07:08 PM
Standard Xtreme setup is Stainless intake, Inconel exhaust valves. They put what I presume are the same valves (aka GIANT) in some 930 cores I sent them.
MST0118 05-30-2024 09:36 PM
The motor should be able to go to 8000 but I want to see what the dyno shows for peak power, it may be lower. For fuel, I plan to use a blend of a racing unleaded with super unleaded. Expected power, I'm hoping for 400, but mainly I want to get good AFRs around the rev range. Mike mentioned on similar engines with PMOs, he can get more than 400. But with MFI, it can take longer to dial it in. Hopefully Mike will chime at some point on that issue, and I'll post the dyno results after the test. For use, I will do some track days with friends, drive on back roads, etc., undecided on racing at this point but it looks fun.
Nice! What cam? Are those stainless valves or Ti? Thanks!
Cam is a custom Elgin (similar to GE80) on a 106 lobe center. The valves are stainless - both intake and exhaust. I discussed Ti with Bill and he thought it was overkill based on expected powerband, etc.
winders 05-30-2024 10:33 PM
Sounds like a fun engine. The slides should be interesting around town. At a real 11:1 I suspect you will need some racing unleaded to avoid knock or pre-ignition. Are the Pankl rods Ti? 130mm or stock? If Ti and 130mm, you should be able to run at 8000RPM. Once you get the MFI tuned it should be a blast!
We have seen some problems with Pauter rockers failing on 8000 RPM engines. Even the better old style cast rockers have problems up there. My race engine had a cast rocker fail at 8000 RPM and a piece of it jammed up the cam causing it to break between the #4 intake and exhaust lobes. I investigated the Pauter rockers and discovered there were issues.
So, for my new 3.746 (102mm x 76.4mm) build, I ended up going with forged rockers from Hastech in Sweden. I am using Carrillo H-beam rods and custom CP pistons (12.5:1) with William Knight proprietary cams. I have to run 110 to 112 octane leaded fuel. The Xtreme heads are also a custom William Knight setup with stainless intake and Inconel exhaust valves. I am using 48mm AT Power shaftless butterfly ITBs with 1 3/4" custom stainless steel William Knight headers and muffler. A MoTec M150 unit controls the EFI and drive-by-wire setups. The 3.6L version of this made 430 HP. But, it was under-fueled with 45mm ITBs and power peaked at 7400 RPM. With more air and fuel, better headers, and cam timing retarded a bit to favor the top end, I hope to get a bit more power and nice bump in torque.
Henry Schmidt 05-31-2024 06:23 AM
Looking like a very nice engine plan.
It was a pleasure working with this customer to help make his dream come true.
One of the true benefits of using some of our products is the design features that take them to the next level. One of these design features is the ability to install your piston and cylinder assembly without installing the head studs. In this build, Mike chose the more conventional assembly technique but the ability to install the cylinder/piston combination without dancing around the studs saves hours in build time not to mention the unfettered ease in installing the piston clips.
I look forward to hearing how this project works out. Old school MFI is not cutting edge but it has a cool factor hard to match.
http://forums.pelicanparts.com/uploa...1717161592.JPG
JoeMag 05-31-2024 01:24 PM
I would venture 400hp is very do-able with the Xtreme heads. ...that being said, they're motors with EFI, no idea on how well MFI can be tuned.
The engine dyno will be great to see, and then possibly a dyno jet chassis dyno to compare to see what you get for losses engine to wheels.
How much do the pistons and wrist pins weigh, and what are top and second ring thicknesses (all of this except wrist pin weight) is on data you got from CP with pistons.
MST0118 05-31-2024 03:36 PM
Yes, the Pankl rods are Ti with 130mm. They have 23mm pins. I was looking for the ones with 22mm pins but the seller didn't have any of those left in inventory so went with 23.
Yeah, unfortunately, I found too late about this. When I told Mike that I had the Pauter rockers, he asked right away when I bought them which was about 4 years ago. He said I should be concerned because Pauter was having coating issues with them at that time. I returned to Brian and he stripped and recoated them. I'm still having second thoughts about the Pauter rockers and may replace to what you have soon. I will need to monitor the wear on these.
I look forward to hearing about your new 3.74 engine, do you think you'll get 30+ more hp compared to the 3.6 version?
The piston weight is 422 grams. Not sure on top and second ring thickness, I sent the box to Mike. I do recall weighing the pins and thought they were heavy, so I bought another set of lighter pins from Jerry at CP (the 23mm pins are heavier), don't have the data on me at the moment.
winders 05-31-2024 04:05 PM
Did you buy new or use Pankl rods? I know they time out in Cup Car engines and then are often sold to people with no warranty. That seems like an interesting game to play. How many hours will you use them before you get new ones?
Even new Pauter rockers seem to have problems at 8000RPM. If you stay under 7500 RPMs you should be fine. I used to view cast rockers as kind of a fuse for money shifts. As you're more likely to break a cast rocker than have a valve bend badly or break which is clearly more catastrophic than a broken rocker. A money shift with forged rockers is a real money shift! I feel fine using forged rockers now as I am using a sequential gearbox with paddle shift. A money shift is now all but impossible.
No, I don't think we will see a 30 HP gain. The displacement increase is only 4.1% so a 17HP gain would be the most I would expect all other things being equal. I hope for a little more than that as we do have more appropriately sized ITBs and better headers. I am expecting the bigger gains to be on the torque side of things.
I'll try to remember to PM you with the results I get from the engine when it is tuned.
stownsen914 06-01-2024 10:05 AM
Like the motor!
Mike gets 400+ hp a 3.6 on carbs, so with Xtreme heads on MFI I’d think you’ll be in that range as well.
I’d have to agree on the wariness on those rockers too. For the motor specs you describe, I understand many builders prefer stock rockers for the reason winders mentioned. In an overrev situation, you have a chance of just breaking a rocker if there’s any piston to valve contact, and that’s is easy to replace. I’m about to assemble a 3.5 with similar specs to yours (no Xtreme heads though) and opted for the stock rockers. Carbs for now but planning to go MFI at some point. I’m doing vintage, so slides would be cool.
David 23 06-04-2024 12:07 PM
I'm curious about the choice of Slide valve intake. Can you talk about the reasons and expectations for non-race application? Did Supertech do any work on the unit, Mittlemotor pieces seem to have had a lot of quality issues.
Henry Schmidt 06-04-2024 04:19 PM
Over the last 40 years when we were looking for reliable rockers for an 8000 RPM engine our go to rocker were forged RSR rockers. They have become crazy expensive and they are a challenge to adjust. You need a large assortment of lash caps and changing them means sliding the rocker shaft out.
The next best option has always been the early adjustable forged rockers that came in early 911 2.0 engines.
They have been replaced over the years to alleviate the "money shift" issue but for those who prefer something special, these are it.
The early rocker has a slightly better ratio 1.5:1 vs 1.45:1, they a lighter 110grams vs 135 and they don't break.
From the factory the contact pad has a chrome face for reduced friction and long life.
When we rebuild them, strip the chrome, we replace the bronze bushing with our proprietary DP4 bushing, surface the pad relative to the new bushing, and a chromium layer of 60 to 80 μm is used.The chrome is then polish to an RA of .2 and blasted with low pressure media and dry film coated.
The obvious problem is the limited supply. We have a few sets on the self but we keep looking.
The friction reduction of the DP4 bushing is maybe the most beneficial change. We believe that this simple improvement may be worth 5 hp and reduced heat in the top end.
http://forums.pelicanparts.com/uploa...1717540707.JPG
winders 06-05-2024 01:59 PM
From the LN Engineering website:
Hastech Engineering's Porsche 911 & 964 forged rocker arms are a drop in replacement for stock rocker arms. Unlike stock cast rockers, these will not break if you have an over-rev or if used in an engine that will see high rpm use above 7400 rpm. Hastech forged rocker has a long pad follower and is based on the design used by Porsche for their forged rockers used in early 911 engines. These rockers enable the use of higher lift performance camshafts and also feature high strength bushings and DLC coating for low friction and long life. Hastech has used these rockers in all their race engines for years and are recommended for all aircooled Porsche 911 engines for both street and track.
Additional information from the Hastech website:
Drop in replacement for stock rocker arms
Will not break like stock cast items.
Steel forging to early 911 shape
Long pad follower
OEM Swivel foot
Weight incl Swivel foot, 125 grams
Enables use of new generation higher lift camshafts
DLC coated with high strength bushing
Race proven for many years
winders 06-05-2024 02:04 PM
http://forums.pelicanparts.com/uploa...1717621428.jpg
Turbo_pro 06-05-2024 03:27 PM
It seems like Hastech Engineering was trying their best to imitate the early Porsche forged rockers and yet ended considerably heavier.
They look very nice and are readily available. When Henry runs out of his early rockers I'll think about using the Hastech rockers. I only have two engines turning those RPMs so I don't anticipate a need anytime soon.
winders 06-05-2024 03:37 PM
Early adjustable forged rockers with elephants feet installed weigh in at around 122 grams. That is with a smaller pad than the Hastech rockers at 125 grams. I fail to understand where the "considerably heavier" idea comes from....
Turbo_pro 06-05-2024 03:55 PM
You are correct, I didn't include the adjuster so the Porsche rockers are just slightly lighter.
Neil Harvey 06-05-2024 04:08 PM
Just to add a little info for those that may not.
You cannot successful regrind the pads on these rocker arms on a valve grinder attachment. There will be those that say they do and can but the geometry of the pad is not something that can be replicated on a Valve grinding attachment.
Common fault by doing it that way is, the adjuster swivel foot will stop lifting the valve and then slide across the Valve tip.
For those don't care, that way is good enough I guess, but for those that want it correct, ask who you have do this; do they have the geometry and does their tooling follow this geometry. Just because the pad looks good doesn't mean it will work correctly.
Add in poor cam profiles many copies of copies, then the wrong rocker geometry, you increase the hertz stresses and up goes the wear and down goes the possible performance.
Its all the little things that add up to more Torque.
winders 06-06-2024 10:11 AM
Most people that do slides these days do it to be period correct.
Slides are not what people pick today for racing unless rules require it. Slides just don't work as well as butterfly setups...partial throttle is not very good and they tend to stick after a while. Butterfly setups are much better except at maximum flow rate wide open. That's where slides have a big advantage. But, you can get roller barrel ITBs which don't have the same issues slides have. Or, you can get AT Power shaftless butterfly ITBs which have all the advantages of a butterfly setup with 98% of the flow characteristics at wide open of the slides and roller barrels.
F1 went away from slides and ended up with roller barrels or butterflies...depending on the team.
MST0118 06-06-2024 09:10 PM
I had Supertec inspect the slides because the older version of Mittlemotor slides did have issues. However, the current version of slides incorporated the issues that Henry identified in a previous thread, so not much had to be done with mine.
Having said that, Mike found some minor issues when fitting them on the engine. For instance, the cross shaft was too narrow between the bearings so Mike pulled out the snap ring out 4.5mm to make it fit. He then machined a circlip groove to keep the cross shaft from moving.
Also, some of the ball sockets were tight to make it a stiff effort to move the slides, so he added grease which fixed that. That's just a maintenance item. So, just a few things like that. Now the slides work good and move easily.
I think the sticking issue can be fixed with maintenance, but I agree with your observation of the superiority of TBs and barrels as compared to slides, especially as you point out F1 abandoned that technology.
But when looking at the older technology in the mid 70s, it seems there was a split of opinion as to whether the slides or HB set worked better. I have never driven a 73, 74, or 75 RSR so I don't have personal experience, but there must have been reasons why Porsche changed to slide valve from high butterfly for its RSRs during 1974 which continued through 75. The slides bumped HP at WOT from 315 to 330, but I'm not sure if this change impacted how the RSRs performed in the races overall comparatively during this time period. I did see some slide valve RSRs win races in Europe, but don't have enough data to see the impact of the change.
The late Steve Weiner thought the slides worked better than the old HB set up due to the lack of throttle linearity in the geometry of the HB. Here's what he said about it on a 911s registry post, which I thought was interesting because he thought slides were better on the street as compared to HB. Steve is probably in the minority. Of course, the new butterfly and barrel set ups are not comparable to the old technology.
http://forums.pelicanparts.com/uploa...1717732165.png
winders 06-07-2024 12:13 AM
Slides are sticky at partial throttle because the vacuum sucks on the slides at a 90 degree angle and that greatly increases the force required to move them. Factor in dirt and it gets worse. At partial throttle, the way the air flows around the slide as it opens is not exactly smooth nor is the shape ideal. Think about how the air comes in and then hits the slide surface straight on and then has find its way to the opening.
I have not done the research but I bet the reason the Factory went with slides is that the rules had a max intake diameter. Slides will always flow more air wide open than butterflies at a given diameter intake. They didn't have shaftless butterflies back then so the flow difference would be quite large at around 11%. That's a big difference!
I think the problem with the high butterfly setup is that the butterflies are just too far from the heads. It seems the best way to go these days is to get the injectors and butterflies as close to intake valves as possible.
MST0118 06-07-2024 06:11 AM
dyno day today
Well, engine on the way to dyno today. Mike put 50 PMOs from a 3.8 racing motor on first so we can get a baseline for something to shoot for. Then he’ll put on the MFI stuff and see what it does. I’m traveling next few days but will share results next week some time.
David 23 06-07-2024 08:36 AM
Thanks Scott, that is pretty much what I thought.
MBruns 06-07-2024 02:22 PM
Dyno day
http://forums.pelicanparts.com/uploa...1717794861.jpg
MST0118 06-07-2024 02:50 PM
Thanks for uploading dyno sheet. I was very pleased with results. Mike did a great job building and tuning motor. The first pull with 50 PMO carbs yielded 395 hp at 7100 rpm but the motor gained 15 with MFI/slides and runs great. Thank you Mike Bruns for building this great motor!
Mark Jung also did a great job with injection pump. It’s perfect. I’m trying to upload the dyno video but need to make file smaller.
jj911c2 06-07-2024 08:28 PM
Congrats - those are great results - going to be a fun drive!
stownsen914 06-08-2024 09:19 AM
Wow, great result
Tonger 06-10-2024 01:25 PM
Wow - what a fantastic build! If the OP is willing to share, I’d like to hear and see more about the car this is going into - transaxle, suspension, etc. Was it hard to dial in the MFI on the dyno?
My engine builder is about to start putting together a similar large displacement 3.65L engine with high butterfly MFI built around a 4.0L RS crank and a 3.0L case - so I’ve been following your build with great interest.
MST0118 06-10-2024 09:33 PM
I have a 73 RS lightweight replica built on a 72 chassis (about 2,000 lbs).
For trans, I’ll be putting in a 77 mag 915 that was rebuilt by CMS that will hopefully handle the torque of the 3.8. Some of the upgrades include NPR mainshaft with taller first and then close ratio gears thereafter. 915 has NPR LSD, CMS retainer and billet side plate and wevo gate shift. 930 flanges/axles.
Maybe Mike can chime in on tuning since he did all the work. The pump worked out great and I know he tried various settings to come up with the right combo. As it turned out he richened up the pump a bit from the posted dyno sheet shown to lower the AFR to about 12.9 at peak power. I think he spent a good part of a day to get it dialed in, including running it on carbs first to get the baseline.
Also for suspension, I am using torsion bars - 33 rear / 23 front, bilstein front and back, tarrett sways bars. Will be using 930 brakes. Unfortunate with RS flares, I’m limited with width for rear tire options but will still be fun.
winders 06-11-2024 02:02 AM
The magnesium 915 should work great assuming you don't do hard launches from a standstill. I used a magnesium 915 with Bill Rader bearing retaining plate and side cover. It had a Guard mainshaft with a useable 1st gear for racing. It also had a Guard 930 LSD and Guard and NPR gears. It would have had all NPR parts by now if I would have kept it. Anyway, my 3.6L race engine had ~430 HP and ~340 ft-lbs torque and my only issues were annual replacement of some synchros as racing caused me to sometimes shift quite a bit faster than is ideal with a 915. Using Swepco 210 I never had any R&P issues and gears lasted a long time.
I used 930 flanges and custom gun drilled 300M axles from Kartek. I suspect the Sway-A-Way aircraft alloy steel axles would work just fine but I didn't want to take any chances. I did not use the thicker 930 CV joints. I used the later 930 CV joints that 32mm thick outside race. With the more powerful engine, I discovered that the Redline CV2 grease wasn't really cutting it. I switched to Neo HPCC#1 grease and that seems to have increased the longevity back to what I was used to.
I used a Rennshift shifter (I still have it if you are interested). I actually bought a Wevo Gateshift kit for the 915 but my research caused me to sell it. Instead, I stiffened the centering springs on the Rennshift. Once I did that, I never again had any issues with shifting into the wrong gear by accident.
JoeMag 06-11-2024 09:33 AM
What was peak HP after you got the high RPM AFR in the 12.9 range?
JoeMag 06-11-2024 09:55 AM
I see data better in graphs so plotted this thing... Impressive! Even more so with CR being only 11-1 and this is engine dyno so none of the over-exaggerated engine to wheel losses.
http://forums.pelicanparts.com/uploa...1718124647.jpg
MBruns 06-11-2024 10:29 AM
Dyno
With the AFR at 12.9 it went to 407 and repeated that, 93 pump gas, 98 degree day and lot’s of humidity, it ran really well, I have got to hand it to Mark Jung at MFI Werks he has been amazing with his pump work , This has been a fun project
Mike Bruns
MoreGAS 06-11-2024 07:28 PM
Hi Mike
We typically find power falls of significantly at 14:1 and higher and can actually miss at about 14.5 and higher on NA high compression engines. Did you have a lambda sensor on both banks and what did you use for exhaust?
When you were able to adjust to(with what a main rack adjustment?) a richer 12.9 where was that at RPM wise , and what about the rest of the curve given that this is a Hotrod streeter and it was already very rich around 5K to 5400(we didn't see below) ? 13.79-14 at Peak Tqe (where cylinder pressure is the highest) is really lean and very likely to get in to knock . Can you post that "12.9" run as it should have picked up more Tqe and hP than the sheet shows under the same conditions. Perhaps that was a different day?
What brand of dyno?
Good work
Kevin
GAS Motorsport
