Rebuilding
Rebuilding porsche 911 engine , rod bearing clearance sitting nice at .002
https://uploads.tapatalk-cdn.com/202...acb96aa152.jpg https://uploads.tapatalk-cdn.com/202...a24331f209.jpg |
Solid first post.
I'm not sure what we're looking at. Is the second picture the engine being assembled?
Generally speaking, it is not a good idea to reuse old Dilivar studs or to use a mismatch upper and lower stud combination. |
I had a though about my earlier post. My comment about head studs was based simply on the pictures you posted. The lower studs look like coated Dilivar. It is possible that some previous builder replaced the Dilivar with Canyon "Super Suds".
They are a coated steel stud designed as a Dilivar replacement. If you test them with a magnet you'll know. If the are magnetic, you're go to go. Just a thought. |
| All times are GMT -8. The time now is 05:32 PM. |
