nb6179505's Avatar
993 hydraulic lifters OUT
seems like everyone has these out of stock, I got enough from our host to do the lower side, still some ticking, so going to replace the upper now.
I ordered, and I was so eager, I guess I ordered the turbo lifters. I've read several places where people used the turbo and NA ones interchangeably with no issues
whats the general consensus? return and wait for NA standard sized ones to replace with the turbo ones? Dimensions seem to be the same when measured with calipers from the old ones that I pulled out and replaced...fyi engine is a ROW 3.6 varioram
Old 07-21-2024, 08:41 AM
Cairo94507's Avatar
The lifters have been out of stock for months now. I order a full set for my '95 3.6 and only received 11. I finally got 1 more from Gaudin Porsche to complete the set. Good luck.
'71 914-6 #0372
'17 Macan GTS
Old 07-22-2024, 11:13 AM
The 9 Store
We change them to solid lifters.
All used parts sold as is.
Old 07-22-2024, 12:28 PM
nb6179505's Avatar
What are the part numbers for solid lifters? They're non adjustable
Old 07-22-2024, 03:06 PM
Jeff Alton's Avatar
That involves backdating the rocker arms and modifying them, then using to old style adjusting screw.
Cheers
www.turn3autosport.com
Old 07-22-2024, 04:12 PM
PCA Member since 1988
What happened to your old ones? I would put one of those back in until you can get a new one.
Which brings up another question: why are you replacing them in the first place?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-22-2024, 11:11 PM
JoeMag's Avatar
Regarding solid rockers.. You do not need to modify the 993's. Use 930 rockers, and have them width clearanced because some will fit and some will not in the 993 cam tower. The bushing needs to put in and not drilled for oiling hole.
Here's one setup with grooved bushing
Old 07-24-2024, 09:47 AM
Cairo94507's Avatar
I swapped them out on my car because the stock lifter has a rubber seal on it; the new ones have a teflon seal that will better hold up over time. Apparently the rubber ones can crack.
'71 914-6 #0372
'17 Macan GTS
Old 07-25-2024, 11:33 AM
Jeff Alton's Avatar
We are saying the same thing Joe lol. Backdate- use the older production parts. Modify- new bushings not drilled and arm clearanced to fit...
Cheers
Old 07-25-2024, 08:35 PM
nb6179505's Avatar
I don't know if anyone read my original post, the question was
, are the turbo ones the same as the NA ones? Can the turbo ones be used on an NA car
Old 07-25-2024, 09:46 PM
Jeff Alton's Avatar
Have You looked in PET to see the part numbers?
https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
Old 07-26-2024, 08:38 PM
nb6179505's Avatar
I have. The part numbers are different for the turbo and Na engine. But I read a post from 20 years ago that someone said they could be used interchangeably.
Simple asking if anyone had experience doing that or do I need to return the turbo ones I ordered mistakenly
Old 07-26-2024, 11:10 PM
