It's a 914 ...
Sealing th e #8 nosecone bearing
I've heard a few folks recommend using sealant like Threebond 1184 on the #8 / nosecone bearing to supplement the o ring. Where is it recommended to put the sealant?
Surrounding the o ring but not on it? On the o ring itself? Some other way? Thanks. |
A smear on the case bore where the o-ring contacts. I use dirko. Just a light smear.
Try not, Do or Do not
We recommend a very light smear of TheeBond 1211 not 1184 on the #8 bearing surface area. We've been doing some testing with Dirko (like JW suggests) as of late and have seen some good results in shear tests on the bench..
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Per Henry, i did ThreeBond 1211 including on the o-ring itself but .... do not block the oil return channel.
Good pics and comments starting here, showing the oil return channel: https://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread-33.html#post10870835 |
