-   -   Custom Thickness Base Gaskets (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1164818-custom-thickness-base-gaskets.html)
mikedsilva 07-25-2024 06:19 AM
Is there an online supplier for copper cyinder base gaskets other than 0.25mm or 0.5mm?
Chasing some custom thicknessses and we don't have them here in Australia... (that I can find).
Mike
cgarr 07-25-2024 06:48 AM
did you check with EBS? I got an assortment from then but don't remember if they were between .25 and .50 I did have some .80 in the pak
Henry Schmidt 07-25-2024 08:08 AM
Mike
Of course there are many different diameters of cylinder bases but we have .25, .50. 1.0. for a few different sizes 1.5 mm for 2.0-2.4 ?
I would have to check.
We have no cooper gaskets for 3.6 100mm cylinders.
I'm trying to get some made but as I wide things down it's low on my list of priorities.
JoeMag 07-25-2024 09:30 AM
Check out LN, in some cases they have 0.010" to 0.040" in 0.010" increments. ...I also just saw in the write up they also do customer thicknesses.
https://lnengineering.com/products/porsche-and-vw-aircooled-cylinders-and-pistons/base-shims.html
You could also contact Jae Lee over at Mirage, I've gotten some customer thicknesses from him.
mikedsilva 07-25-2024 03:49 PM
Yep, I sent an email off before I submitted this post.
Just got a reply that they have 1mm, 0.5 and 0.25mm. No other thicknesses so not sure how you ended up wtih 0.8?
Just waiting for freight quote and will order a few sets.
I did also email a well known supplier (often on pelicanparts forums) a few weeks ago, but never got a reply. Not a big deal.
Henry Schmidt 07-25-2024 04:32 PM
Just got off the phone with Charlie at Wrightwood Racing and after a long F1 discussion we got around to expanding his options. He'll be getting back to me.
Of course we have different opinions about how Spa will end up.
I'm a solid McLaren fan even though they brain trust keeps screwing Lando out of !st place finishes.
mikedsilva 07-26-2024 03:04 PM
How do we get Pelican Parts to be able to offer alternatives to the 0.25 and 0.5mm gasket? These are the only two options I can see online..
Henry Schmidt 07-26-2024 03:13 PM
That supplier is me and I get some 200 email a day so some times I miss one. Sorry I missed yours.
.50 + .25 = .75mm All good. you will never need to get any closer than that.
Rosco_NZ 08-06-2024 11:06 AM
Ollies in Arizona can help too.
