Custom Thickness Base Gaskets
Is there an online supplier for copper cyinder base gaskets other than 0.25mm or 0.5mm?
Chasing some custom thicknessses and we don't have them here in Australia... (that I can find).
Mike
Always learning.
www.aircooledporsches.com.au
Old 07-25-2024, 06:19 AM
abit off center
cgarr's Avatar
did you check with EBS? I got an assortment from then but don't remember if they were between .25 and .50 I did have some .80 in the pak
______________________
Craig
G2Performance
Old 07-25-2024, 06:48 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Mike
Of course there are many different diameters of cylinder bases but we have .25, .50. 1.0. for a few different sizes 1.5 mm for 2.0-2.4 ?
I would have to check.
We have no cooper gaskets for 3.6 100mm cylinders.
I'm trying to get some made but as I wide things down it's low on my list of priorities.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-25-2024, 08:08 AM
JoeMag's Avatar
Check out LN, in some cases they have 0.010" to 0.040" in 0.010" increments. ...I also just saw in the write up they also do customer thicknesses.
https://lnengineering.com/products/porsche-and-vw-aircooled-cylinders-and-pistons/base-shims.html
You could also contact Jae Lee over at Mirage, I've gotten some customer thicknesses from him.
Old 07-25-2024, 09:30 AM
Yep, I sent an email off before I submitted this post.
Just got a reply that they have 1mm, 0.5 and 0.25mm. No other thicknesses so not sure how you ended up wtih 0.8?
Just waiting for freight quote and will order a few sets.
I did also email a well known supplier (often on pelicanparts forums) a few weeks ago, but never got a reply. Not a big deal.
Always learning.
Old 07-25-2024, 03:49 PM
Just got off the phone with Charlie at Wrightwood Racing and after a long F1 discussion we got around to expanding his options. He'll be getting back to me.
Of course we have different opinions about how Spa will end up.
I'm a solid McLaren fan even though they brain trust keeps screwing Lando out of !st place finishes.
Henry Schmidt
Ph: 760-728-3062
Old 07-25-2024, 04:32 PM
How do we get Pelican Parts to be able to offer alternatives to the 0.25 and 0.5mm gasket? These are the only two options I can see online..
Always learning.
Old 07-26-2024, 03:04 PM
That supplier is me and I get some 200 email a day so some times I miss one. Sorry I missed yours.
.50 + .25 = .75mm All good. you will never need to get any closer than that.
Henry Schmidt
Ph: 760-728-3062
Old 07-26-2024, 03:13 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Ollies in Arizona can help too.
Old 08-06-2024, 11:06 AM
