Early engine spec question
Doing a build on early 2 liter T engine. Based on upgrades have some piston/valve clearance issues due to bigger valves and DC 30 cams.
From the experts, is there any difference in valve angles ( in essence the heads) in T engine and early S (68/69) heads other than size of valves.
TOT
Old 08-13-2024, 11:09 AM
Terry, valve angle is the same
Bruce
Old 08-15-2024, 07:26 AM
Heads
Thanks Bruce……We were figuring they should be , but Cam Mfg said something like the valve reliefs in early S pistons were at an odd angle, so needed to check that box before we started trying to fly cut pistons to provide clearance for new cams (DC30s).
TOT
Old 08-15-2024, 09:08 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Recheck that cam timing
Old 08-16-2024, 02:34 PM
Clearance
Pretty sure he did several times.
TOT
Old 08-17-2024, 06:03 AM
