Early engine spec question
Doing a build on early 2 liter T engine. Based on upgrades have some piston/valve clearance issues due to bigger valves and DC 30 cams.
From the experts, is there any difference in valve angles ( in essence the heads) in T engine and early S (68/69) heads other than size of valves. Thanks
TOT |
Terry, valve angle is the same
Bruce |
Heads
Thanks Bruce……We were figuring they should be , but Cam Mfg said something like the valve reliefs in early S pistons were at an odd angle, so needed to check that box before we started trying to fly cut pistons to provide clearance for new cams (DC30s).
TOT |
Rosco_NZ
Recheck that cam timing
Clearance
Pretty sure he did several times.
TOT Last edited by zztot; 08-24-2024 at 08:38 PM.. |
