Timing idler gears
I am making progress assembling my motor and ran across this. Before I button up the timing chains can someone weigh in on this sloppiness of the idlers? Am I missing something here? I have updated idlers that do not require the old spacer, but there is this gap now. Am I to assume that these will just center under tension and fall into place? Just wanting to be sure before I seal this up.
See video short: https://www.youtube.com/shorts/g1lnHZ2wWxI See image below: http://forums.pelicanparts.com/uploa...1724003252.jpg |
There is nothing missing that’s so there is some centering of the chain available.
Bruce g |
Bill |
The cover will restrict movement .. but you do want the adjuster shaft to be central on the adjuster foot.
From memory I had to machine a little off the face of the tensioner to ensure they aligned correctly .. which is when the tensioner is all the way in on the shaft. |
| All times are GMT -8. The time now is 01:27 PM. |
