Drive it like u stole it.
jonesb930's Avatar
Timing idler gears
I am making progress assembling my motor and ran across this. Before I button up the timing chains can someone weigh in on this sloppiness of the idlers? Am I missing something here? I have updated idlers that do not require the old spacer, but there is this gap now. Am I to assume that these will just center under tension and fall into place? Just wanting to be sure before I seal this up.
See video short: https://www.youtube.com/shorts/g1lnHZ2wWxI
See image below:
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 08-18-2024, 10:50 AM
There is nothing missing that’s so there is some centering of the chain available.
Bruce g
Old 08-18-2024, 12:02 PM
jonesb930's Avatar
Bruce g
Thanks Bruce! I suspected this but wanted some reassurance before I closed it up.
Bill
Bill Jones
Jupiter, FL
Old 08-18-2024, 12:36 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
The cover will restrict movement .. but you do want the adjuster shaft to be central on the adjuster foot.
Old 08-18-2024, 12:58 PM
Rosco_NZ
From memory I had to machine a little off the face of the tensioner to ensure they aligned correctly .. which is when the tensioner is all the way in on the shaft.
Old 08-18-2024, 01:00 PM
