3.2 carrera 87 cylinder boring with aftermarket cylinders
Hi Gang
I’m wanting to rebore my 87 3.2 cylinders with some new aftermarket pistons.can anyone recommend who I can ship my cylinders off to. I just want to up to a 3.3, nothing crazy. Thanks |
The 9 Store
I send my cores to EBS engine builder supply and they send me bored and plated cylinders. Pretty easy.
All used parts sold as is. |
Chain fence eating turbo
Yep, EBS
PCA Member since 1988
I know a few years ago there were a high number of plating failures on cylinders that had been replated. Has anyone had failures recently?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Navin Johnson
Millenium
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Was Millennium the one having problems, and the EBS are good?
The issue with EBS (Millennium) was surface finish. Mahle specs 3-5 RA and Millennium was honing to 15+/-3. Nikasil plating is extremely hard and the rough surface would scratch the rings, leading to high oil consumption. This was solved a few years back and I haven't heard of any issues since then.
I bought pistons from Millennium and they sized the bores to the pistons. However, pricing for this service has increased over the years and isn't as as favorable compared to a new P&C set from Mahle nowadays. Can't hurt to quote it though.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
I had a set done by Millennium about a year ago. Price was $2400 for 6 cylinders. I specified the RA I wanted the cylinders finished to.
John |
$2400 plus pistons, wrist pins, rings, etc or just buy a new Mahle P&C set for $4500 (PN #PS98-010)
i was looking for 1 cylinder to replace one that came back from Millennium with porosities. So I tried with EBS and they could not deliver any finer than Ra15
80SC (ex California) |
DIY wrencher
The math is even easier when you can get the set for $3700 from TH MS... google is your friend.
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
I saw some less expensive options on google but wanted to quote a price from a retailer I knew was legit.
DIY wrencher
I ordered a set from them, no problems. Not sure how but they have crazy low prices on Mahle parts....
$1300 cheaper than Pelican sells them for seemed too good to be true. Thanks for the heads up. I normally try to purchase parts from our host (and fellow Pelicans), but that's a ridiculous savings.
The 9 Store
Pelican has a very high markup on mahle cylinders. I think we figured out that we can sell them for $1k less and still make a decent margin.
Senior Member
Th ms? =?
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
