Unique cam nuts and washers.
Have a set of cams that are part of my build that originated as a set of rsr cams. They use a fine threaded nut. Anybody have a set around?
Old 09-01-2024, 06:31 AM
40 years and I had one set on rsr and I believe from memory they are 32mm on the shoulders. Check with the size but I know they weren’t 46mm.
Bruce
Old 09-01-2024, 09:45 AM
Yes. Smaller. But also different threads
Old 09-01-2024, 07:21 PM
Check with Henry.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 09-02-2024, 06:29 AM
Hi Gene,
WET '65 906, Fig 1-4, #70, 901.105.173.00 Nut for camshaft [Mutter für Nockenwelle] Qty: 2
Ti, Polished, $29.82 each
I emailed you a copy of this post.
Jimmy
Old 09-02-2024, 09:24 AM
This place is incredible.
Jim, I sent you an email.
Old 09-02-2024, 09:56 AM
