elring sealing compound
I'm doing a an engine for another shop. Instead of Loctite 574 they supplied Elring
EL-LIQ 74. I looked it up and the description is very similar to the 574. Any experience with it. I have some 574 in stock and will be using that. But always good to know. thanks |
PCA Member since 1988
See the thread on the latest recommended sealants
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
