-   -   Headstuds (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1167003-headstuds.html)
Geneulm 09-24-2024 06:24 AM
Absolutely
Turbo_pro 09-24-2024 08:29 AM
Originally Posted by Geneulm (Post 12326560)
Absolutely
Based on what ? Have you used them? How many engines have you built?
540964 10-02-2024 05:04 AM
pmax 10-03-2024 03:46 PM
Ah, a headstud thread.
I'll add these, Dilivar studs mind you, to the discussion.
Originally Posted by Turbo_pro (Post 12321376)
Why?
http://forums.pelicanparts.com/uploa...1727995420.jpg
These PMS fellas probably built a bunch over the past 20 years.
Does that suffice ?
vl5150 10-03-2024 03:55 PM
I bought my '89 3.2 as a project as it had 3 broken head studs on cylinders 1, 4, and 5. So I went right to the Supertec ones after reading the threads here. So far so good. I really liked not having to set the stud height on them as well and not having to use the barrel nuts.
