rennzeit's Avatar
Fan shroud injector holes too big?
How much gap is acceptable?
This seems like too much to me.
Any ideas on how to fix without ordering another shroud welcome.
1972 914-6 2.5L Gemini Blue
1973 914-6 MetalCraft Racing C-Prod/TransAm/IMSA history
Old 10-27-2024, 04:39 PM
Try not, Do or Do not
Henry Schmidt's Avatar
You could try cutting a high temp rubber grommet to fill the gap.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-27-2024, 05:50 PM
rennzeit's Avatar
Sometimes the simple solution is the best.
Thanks Henry
Old 10-27-2024, 06:06 PM
Behind the Sun
Where did you buy that aftermarket shroud?
I think that's where the problem is.
Old 10-28-2024, 06:53 AM
Factory shrouds had large cutouts like that so the shroud can be installed with the injectors in place. When I cut them out, much tighter, injectors must be installed after shroud is in place. Just my observation. I wouldn’t be concerned.
Old 10-28-2024, 08:58 AM
rennzeit's Avatar
Yes, Damon explained this to me as well, and I found a thread showing a 73S shroud with the larger injector openings from the factory in post #6 here:
https://www.early911sregistry.org/forums/showthread.php?60749-1973-S-MFI-quot-The-Red-Shroud-quot
I will still probably use some high-temp grommets to seal things up
Old 10-28-2024, 11:53 AM
Do I see a modern injector going into a MFI hole adapter?
Sent from my SM-S918B using Tapatalk
Old 11-03-2024, 11:02 PM
