Originally Posted by Axel84 View Post
Thanks 40/38 got it
Maybe Mr. "hylla" has a 3.2 Carrera head so you could measure the port size yourself
Old 10-18-2024, 02:06 PM
Evan Fullerton's Avatar
For what it’s worth, I told Bill at Xtreme I was building a SS 3.3L that would make peak power around 7200 and he still recommend a 42mm intake port to go with the 53mm intake valves. He wasn’t remotely concerned about loss in air speed on only a 3.3L
Old 10-18-2024, 03:12 PM
Racer
winders's Avatar
My problem was mainly with the port size mismatch and having air bounce off the lip created by using ITBs with 43mm ports on 39mm intake port heads.
The problem with the ITB setup asked about is the combination of ITB size and port size on a 3.2SS engine. 50mm/43mm is just too big for a 3.2 street engine.
Also, My 3.746L race engine that makes 450 HP and revs to 8,000 RPM uses Xtreme heads with 52.8mm intake valves and 45mm intake ports. There is no way a 3.2L 7000 RPM street engine should be using 53mm intake valves. Nope. That makes no sense at all. With those intake valves you need 1 3/4" headers to match them. Again, that makes no sense at all. All that does is slow down airflow into the engine and destroys low-end to mid-range torque.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-18-2024, 04:37 PM
Here from Rennsport Systems:
https://rennsportsystems.com/letstalk/ignitions-cylinder-heads-pistons-cylinders-and-the-bottom-end/
Old 10-19-2024, 05:31 AM
Robert Espeseth's Avatar
Axel, will get some 46's in to AB Garage soon, that will be a better fit for your set-up
Old 10-26-2024, 10:32 AM
totle's Avatar
Cool and agree
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 10-26-2024, 11:38 PM
