Cheap oil pumps
Has anyone tried one of these new cheap (~$150) oil pumps that are on eBay?
Looks like they copied a four rib version. Only interested in firsthand experience. |
Wow! Scary kinda but almost makes me want to buy one just to see.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
It's a 914 ...
It would be interesting to see how one measures up. An oil pump is a critical component of an engine, but also a pretty simple device at its basis. Measurements of the components would be one thing, and testing the hardness of the gears and shafts would be another.
giving how critical an oil pump is, and where its located, its so hard to find someone welling to take the risk trying a knock-off oil pump. This is a precision made part and needs certain amount of metal hardening process.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Like putting a Chinese prop on your airplane.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
You are right.
gearhead
Send your oil pump to Glenn Yee and have it properly remanufactured.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
winter
But I’m sure someone, somewhere, will try. Doubtful that the Guinea Pig will be on these forums though.
Tom '76 Targa |
Constitutional Liberal
Henry has been doing air-cooled 911 oil pump mods since the 80's. Supertec Performance 445 Golden Road, Fallbrook, Ca. 92028 Ph (760)728-3062 Email: supertec1@earthlink.net
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
