PCA Member since 1988
And, if you narrowed the engine overall without adding shims under the cylinders, your pistons may be getting too close to the heads and valves. Check the clearance, if you haven't already.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-24-2024, 02:04 PM
The larger idler wheel and machining the tensioner box solved this. Thanks for all the input!
Old 12-05-2024, 07:31 AM
