-   -   Replacment pins for Cam Holding Tool? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1170064-replacment-pins-cam-holding-tool.html)
JoeMag 11-11-2024 02:42 AM
Anyone know where to get replacement pins?
http://forums.pelicanparts.com/uploa...1731321715.jpg
stownsen914 11-11-2024 05:08 AM
Not sure if they are a stand size i.e. available from Porsche parts suppliers, but McMaster is a good place for generic hardware items like pins
Dpmulvan 11-11-2024 05:11 AM
You’ll have to make your own pin.
Magyar Kiwi 11-11-2024 04:18 PM
Hi
You may be able to use the rollers from a roller bearing.
These come in various diameters and lengths.
You can buy them individually, (or in small quantities) from your local bearing supplier.
Cheers
Flat6pac 11-11-2024 06:33 PM
I believe they’re flat spotted on the inside of the pin.
Regardless, I’m sure it’s all metric.
Bruce
Dpmulvan 11-12-2024 05:27 AM
Get a micrometer measure pin, buy a steel rod off McMaster, grind a flat spot, pound in, done.
JoeMag 11-13-2024 12:55 PM
Thanks Guys... I removed a pin again and noticed the "flat" goes quite far down on the pin. Actually enough that you can cut-off the part that "sticks out" and have enough flat to reinstall.
In any case, measured and they're 6.00mm X 40mm. So have a few 6mm gauge pins coming.
Dpmulvan 11-22-2024 08:33 AM
Make sure tool is flush with sprocket and pins are all the way in before torquing on it.
Alan L 11-29-2024 04:23 PM
When I am looking for bits like that I find drill shanks useful. Come in a range of sizes - metric and imperial. :-)
Alan
brighton911 12-01-2024 07:07 AM
Good tip Alan L !
Abijawara 12-01-2024 04:15 PM
You might have to make your own opinion
JoeMag 12-02-2024 03:01 PM
Just tried my mine again after I pulled out a pin and chopped it off. Works great again.
MBruns 12-03-2024 02:57 AM
McMaster-Carr
