Replacment pins for Cam Holding Tool?
Anyone know where to get replacement pins?
It's a 914 ...
Not sure if they are a stand size i.e. available from Porsche parts suppliers, but McMaster is a good place for generic hardware items like pins
You’ll have to make your own pin.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Hi
You may be able to use the rollers from a roller bearing. These come in various diameters and lengths. You can buy them individually, (or in small quantities) from your local bearing supplier. Cheers |
I believe they’re flat spotted on the inside of the pin.
Regardless, I’m sure it’s all metric. Bruce |
Get a micrometer measure pin, buy a steel rod off McMaster, grind a flat spot, pound in, done.
Thanks Guys... I removed a pin again and noticed the "flat" goes quite far down on the pin. Actually enough that you can cut-off the part that "sticks out" and have enough flat to reinstall.
In any case, measured and they're 6.00mm X 40mm. So have a few 6mm gauge pins coming. |
Make sure tool is flush with sprocket and pins are all the way in before torquing on it.
When I am looking for bits like that I find drill shanks useful. Come in a range of sizes - metric and imperial. :-)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Good tip Alan L !
1986 Targa Guards Red 2021 MT09 SP |
Banned
You might have to make your own opinion
Just tried my mine again after I pulled out a pin and chopped it off. Works great again.
McMaster-Carr
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
