-   -   Christmas Build, 3.2 Short Stroke, 10.1 CR (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1171904-christmas-build-3-2-short-stroke-10-1-cr.html)
snbush67 02-23-2025 02:40 PM
Air flow tins installed.
Taking things slow.
http://forums.pelicanparts.com/uploa...1740350367.jpg
G450X 02-23-2025 03:20 PM
Rings
Thanks for the info, I’ll check with Mahle, but I think the new P&C 3.0 to 3.2 ring sizes are different. I thought you had reconditioned an old set.
dedyplay 02-26-2025 02:57 AM
Very nice
snbush67 03-09-2025 03:23 PM
Had a few hours today to clean and prep the camshaft housings.
http://forums.pelicanparts.com/uploa...1741558657.jpg
trond 03-15-2025 11:05 AM
i too got new cylinders from Mahle. And I had a problem to get a good seal to the heads, because my cylinders were not chamfered. While the cut in the heads is radiused. Put the heads on in the vertical. Also do leakdown to verify they seal before proceeding. I ended up chamfering the cylinders. Fixed it
snbush67 03-15-2025 02:49 PM
Dang it, I wish I had read this earlier. I just put the heads on and the cam housings this morning. I’ll check before I proceed further.
http://forums.pelicanparts.com/uploa...1742075033.jpg
snbush67 03-15-2025 06:28 PM
I don’t see any issues with the heads sealing.
http://forums.pelicanparts.com/uploa...1742088417.jpg
trond 03-16-2025 02:52 AM
agree. maybe I was unlucky. When I installed my heads 1-3 was installed vertical. None of these leaked. Heads 4-6 were installed with engine flat. 2 of these leaked. Maybe my issues came from my heads had been recut 0.25mm and radius could be different.
snbush67 03-16-2025 05:40 PM
I appreciate the “heads” up ;) it was a good idea to check.
snbush67 03-16-2025 05:46 PM
A little progress, chain boxes installed, cam shafts and sprockets are on.
http://forums.pelicanparts.com/uploa...1742172068.jpg
Ovis 03-16-2025 10:21 PM
Nice work, looks beautiful! I am hoping to catch up to you with my build here in a few days, just waiting on a few more parts.
snbush67 03-17-2025 11:36 AM
Chain Sprocket Alignment.
2 shims on the left and 4 shims on the right.
Left side:http://forums.pelicanparts.com/uploa...1742236486.jpg
Right Side:
snbush67 03-19-2025 07:22 PM
Thanks. I hope your parts arrive soon and your build goes great.
trond 03-20-2025 12:00 AM
following this ! I have similar build and also the same k75 cams on order. One question on ring gap you have 0.0175 ring gaps. A lot more than porsche build specs. Why ? Asking because I was confused with the CP/Carillo gap specs compared to porsche specs. I am thinking air cooled aluminium cylinders vs cast iron and different thermal expansion. Circumference (length of piston ring that expands) of a 98mm bore vs a 95 mm bore is insignificant
LukasM 03-20-2025 04:21 AM
Very nice work with great attention to little details Shane and Ian! Taking notes for my engine building file, will be spending some extra time for parts prep to avoid leakage and scratches in these very expensive P&Cs!
Hi Trond,
Can you please explain or ideally show a picture where you would place a chamfer on the cylinder? I get it for the heads since the chamber is sized for a 95mm bore, so that it matches the bigger bore below.
Cheers,
Lukas
Ovis 03-20-2025 09:04 AM
Got my missing ring and moving along. Hope to have the chain boxes and cams installed today.
snbush67 03-20-2025 05:09 PM
Good question, the rings were gapped at 0.0175” right out of the box, so I couldn’t get less gap if I wanted to. Fortunately that is right where we needed them and on the edge of Mahle recommendations. The gap determination involved Ian’s experience and consultation with other renowned builders.
http://forums.pelicanparts.com/uploa...1742515394.jpg
snbush67 03-21-2025 07:10 PM
Set up for timing.
Ready to get timing.
http://forums.pelicanparts.com/uploa...1742608406.jpg
#1 valve lash adjusted.
Mechanical chain tensioners in place.
Verified TDC and all timing marks.
Old school degree wheel mounted to the fly wheel. Wheel of fortune style.
snbush67 03-21-2025 07:51 PM
The plan was to get timing done tomorrow, but things went smoother and quicker than expected and I’m done or I screwed something up and I’ll figure it out tomorrow.
A quick call to William Marshall got the Cam card and directions to set these up at 0 valve lash, 050” at 27 degrees before TDC.
http://forums.pelicanparts.com/uploa...1742609672.jpg
Both camshafts installed with the key ways pointed up and sprockets pinned.
Left side (1,2,3) From TDC I turned the crank until #1 valve was at .050” then removed the pin, rotated the crank until the degree wheel was at 27 degrees before TDC, and put the pin back in. Checked by turning the crank two revolutions while verifying on the second rotation that at 27 degrees before TDC the intake valve was at .050”. It was.
Then to the right side (4,5,6) key way was pointed down. Installed rocker on #4 and dial gauge, adjusted valve lash to zero. Rotated crank until crank until #1 valve was at .050” then removed the pin, rotated the crank until the degree wheel was at 27 degrees before TDC, and put the pin back in. Checked by turning the crank two revolutions while verifying on the second rotation that at 27 degrees before TDC the intake valve was at .050”. It was.
http://forums.pelicanparts.com/uploa...1742611771.jpg
I’ll adjust valve lash to running spec tomorrow and check that each side is at .047” at 27 degrees before TDC. degrees. I’ll double check everything and valve to piston clearances as well.
snbush67 03-26-2025 05:48 PM
Timing is done, rockers installed and valves adjusted.
http://forums.pelicanparts.com/uploa...1743036352.jpg
Ovis 03-26-2025 06:46 PM
Awesome work! This week I've been able to set the cam timing, rockers, and basically get the long block buttoned up. Today we test fit the engine tin and will get that off to powder coat. It's a great feeling being almost to the finish line.
Nice work, can't wait to see your finished motor!
snbush67 03-27-2025 05:24 PM
Wow, you’ve been busy. It might be a while to the finish for me, I’ve slowed down a bit.
I’m contemplating what system to use for twin plug, and catching up on other projects.
I did get the chain tensioners primed and installed and verified valve clearances are still good.
http://forums.pelicanparts.com/uploa...1743121162.jpg
snbush67 03-27-2025 07:26 PM
Quick Check for valve clearance’s. 1 and done.
I put in a call with William Marshall, and asked him to help me verify if my valve clearances were good. After a long explanation of what I had been doing he simply said “Go to top dead center”, I said “I’m there”, he then said “go to # 4 and measure the exhaust clearance”. I used my special Icarp magical valve lever (picture below) and noted well over .25’ of travel, I said, “over a quarter of an inch”. He said “one and done, you’re good”.
I thanked him as he had another call coming in and pondered the physics of what had just happened.
Most in this forum probably know this, but here’s my thoughts.
Check valve clearance at valve overlap for cylinder #4, with the engine at TDC for cylinder #1.
Why? Valve overlap for cylinder 4 happens when it reaches TDC during the transition from the exhaust stroke to the intake stroke. The firing order is 1-6-2-4-3-5. Cylinders 1 and 4 are on opposite sides of the engine.
When cylinder 1 is at top dead center (TDC) on the intake stroke, cylinder 4 will also be at TDC, but on the exhaust stroke. This is because the two pistons are 360° apart in the four-stroke engine cycle.
So, the piston in cylinder 4 will also be at its highest point (TDC), but completing the exhaust stroke, preparing for the intake stroke to follow. Valve overlap occurs at the end of the exhaust stroke and the beginning of the intake stroke. During this phase, both the intake and exhaust valves are slightly open to allow better cylinder scavenging and airflow into the combustion chamber.
http://forums.pelicanparts.com/uploa...1743128740.jpg
snbush67 03-28-2025 09:37 AM
Oil cooler installed.
http://forums.pelicanparts.com/uploa...1743179736.jpg
PeteKz 03-29-2025 12:10 AM
Shane: Correct.
A couple years ago I wrote up about how to check valve clearance at overlap, because that's where the valves get closest to the pistons. You don't need the Stomski tool, although it's handy. Instead, I turn the valve adjusters down to make the valve contact the piston (gently), counting the turns. The adjuster screw pitch is 1mm, so every full turn is 1mm of valve clearance. I check both the #1 and #4 pistons at overlap because I want to be sure there aren't any differences from one side to the other, due to cam timing slipping or some defect in the cams.
In my case, using the M1 cam and the Mahle Sport 3.2 "10:1" pistons, my valve clearance at overlap was around .050". I have a tight clearance because the Mahle pistons are domed on one side without valve cutouts, and the M1 cam uses all the available lift and duration with those pistons, and I deleted the copper base gaskets to get a tighter combustion chamber and squish/quench (.030" deck clearance at the edge of the piston/cylinder/head).
You had 0.25" of valve clearance because the pistons you used have very deep cutouts. Those pistons are designed for racing engines with high lifts, much higher than what you're running.
MoreGAS 03-29-2025 11:38 AM
You guys need to be careful here as TDC is not always the point where the piston is closest to the valve on either intake or exhaust sides. If you use a degree wheel to set cam timing you can get a very good picture of the nature of your camshaft(ramps on lifting and closing sides and rate of increase in lift per degree of crank rotation) , and when the valves are the closest to the piston and often it is roughly 10 degrees away from TDC I recall(note book not near me) on the intake side. This is especially true with more aggressive cams as the intake valve opens 20-30-40(or more) degrees BEFORE the piston is up at TDC.
Here is how we check this: Set your cam to desired spec, after you have hopefully found true TDC w a piston stop and a degree wheel as the pulley marks and fan housing's are often not right on, then then run the intake valve in 1mm at at time initially from 0 lash (1 turn is .040" and you can watch this with your micrometer still on) . Turn the engine around 2 revolutions gently as you get towards TDC on firing no . 1 . Back out the exhaust lash to a whole bunch 1st I should note so valves don't tangle. Then go again in 1/4 turn increments or .010" . Keep going until it hits, and you will see it is very very often not at TDC. The intake valve is opening long before TDC getting a head start on the intake stroke at the end of the exhaust stroke. Once done back it off about .005 and you learn your exact clearance within .005" or so. Pro tip- Do this with only one cam timed or you will have to redo both sides if you have to readjust your cam timing because you have inadequate clearance on one valve or the other.
We record this info as if we have a problem later, we learn exactly what we can get away w certain cam, valve train spec, springs, retainer, valve weights , spring pressures etc., level of over Rev (from data loggers). We of course have limits we know not to exceed on how close we can get away with, and some clients are much harder on equipment than others, so all this needs to be accounted for, and over revs can exceed what one dreamed was even possible.
Then we do the exact same process on the exhaust side, cam still at same timing spec, but now you back off the intake valve rocker several turns from TDC firing NO 1(both valves closed) , and run in the exhaust rocker .040", .060, .080" .100" ...till it hits. Turn the engine slowly 2 turns (all spark plugs out so easier to turn) once you get in to the area where it hits around but not at TDC likely. Then you know almost exactly what you have for clearance. Recall the piston is chasing the Exh valve shut on the exhaust stroke( and this is why a big over rev often breaks a rocker = tags the exhaust valve to piston often -valve float or loss of control- and hopefully doesn't bend the valve ), and the valve doesn't actually close until longer after TDC, 30 degrees on a more racey "cammed" engine.
We use this data to then modify our custom piston designs so we don't have one size fits all" giant ass valve pockets" we don't need for next engine like this we do to the same spec(all things equal) . Piston manufacturers commonly make these pockets very deep to avoid come backs from folks having clearance issues, especially off the shelf designs. Streetcar designed pistons have very little valve reliefs so then one cannot fit much additional camshaft, a real bummer. Sometimes there is not enough dome thickness to cut your own valve reliefs, so a different piston or milder cam is required to go forward. This is often why from a new or totally different design or spec standpoint, we end up building an engine 2X, once to chk everything fits", and then the final time after some mod's perhaps. We have had Mahle give us a 3D printed custom piston model to mock up, to make sure the design fits before producing real parts which can waste time and material if a detail missed a bit.
Happy engine-ing
BeST
Kevin
GAS Motorsport
snbush67 03-29-2025 04:19 PM
Originally Posted by PeteKz (Post 12437159)
Shane: Correct.
Thanks Pete, I’ve actually mapped these cams with a degree wheel so I have that all taken care of. I’m not going to post it though because it’s William probably proprietary information.
snbush67 03-29-2025 04:39 PM
Happy engine-ing
BeST
Kevin
GAS Motorsport
Thanks Kevin,
Great info, yes these pistons have deep pockets, I’m probably going to end up building it again later with twin plug, no base gaskets, higher compression and closer clearances. I did use a piston stop and am using a degree wheel so I have that going for me.
My notes show my exhaust valve closes at 15 degrees, I’m going to go back and check.
PeteKz 03-30-2025 12:21 AM
Kevin, correct. You should check the valve clearance from 10 degrees before to 10 degrees after TDC to know where the valves are closest. That was in my longer instructions a couple years ago.
In Shane's case, with 1/4" of clearance, he isn't anywhere near having valve contact, no matter how he times the cams.
Kiddwayaa 03-30-2025 01:19 AM
Nice project…
snbush67 03-31-2025 06:56 PM
Originally Posted by Kiddwayaa (Post 12437615)
Nice project…
thanks…
…. now where did I leave those chain housing gaskets?
PeteKz 03-31-2025 10:36 PM
To find them, you will have to order new ones. Then you will find the old ones. BTDT.
snbush67 04-01-2025 06:07 PM
That’s how it goes, ordered. Still havnt found the others but I’m sure they’ll turn up.
Fan fit.
http://forums.pelicanparts.com/uploa...1743555884.jpg
The tdc line on this fan was 2 degrees off, also the new pully was too close. I took .040” off and used a chisel to punch a new tdc line.
snbush67 04-01-2025 07:12 PM
Buttoned up.
Buttoned up.
http://forums.pelicanparts.com/uploa...1743559920.jpg
snbush67 04-04-2025 09:42 PM
Headers and muffler bolted on. Fitting the engine shroud and surrounding bits.
http://forums.pelicanparts.com/uploa...1743828010.jpg
Ovis 04-04-2025 11:08 PM
Dang, you passed me. Waiting for the engine tin to come back from the powder coater, then it's a wrap. Looks great man!
snbush67 04-05-2025 10:34 AM
Build Leak down #s
Dry, cold, fresh build, pre start up, - these #s don't look too bad.
http://forums.pelicanparts.com/uploa...1743874213.jpg
PeteKz 04-06-2025 01:13 AM
Time to fire it up!
snbush67 04-06-2025 02:43 PM
Originally Posted by PeteKz (Post 12441803)
Time to fire it up!
Yes sir it is. Just prepping the car doing some dirty work, going through the oil lines and coolers, rinsing everything out. There was a significant amount of fine brass grit from the previous crank gear that left a sheen on the oil surface when I drained the lines.
snbush67 04-06-2025 05:38 PM
Oil tank, lines and coolers are prepped for installation.
http://forums.pelicanparts.com/uploa...1743986115.jpg
