-   -   Christmas Build, 3.2 Short Stroke, 10.1 CR (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1171904-christmas-build-3-2-short-stroke-10-1-cr.html)
snbush67 04-12-2025 12:50 PM
The engine is in.
http://forums.pelicanparts.com/uploa...1744487160.jpg
Old H2S 04-12-2025 01:04 PM
Zoom zoom..
snbush67 04-14-2025 05:42 PM
Engine is running. Changing the jetting and fixing an oil leak. Missing a crush washer at the oil pressure sender between the block and the case.
http://forums.pelicanparts.com/uploa...1744677626.jpg
http://forums.pelicanparts.com/uploa...1744677665.jpg
Old H2S 04-15-2025 09:14 AM
FAIL..Tear it down and do it again.
Joesmallwood 04-15-2025 05:57 PM
Saweet!!
snbush67 04-15-2025 09:45 PM
Break-in is done, leaks have been eliminated. Butt dyno tuning begins.
Started with PMO 46 on normal height manifolds/42chokes/ F11 tubes/ 187 Fuel/ 187 Air/ 57 Idles.
13.6 at idle 950
12.7 through 2800
14.6 - 18.0 through 3500 (this isn’t good, small hesitation, bumpy, at light throttle)
13.6 - 11.4 through redline (7000)
Changed fuel jets to 200
12.8 at idle 950
12.5through 2800
13.6- 17.3 through 3600(this still isn’t good, still small bumpy blurps)
13.6 - 10.0 through redline (7000) (this is to fat)
Installed the 123 distributor with MAP connected and that smoothed things out a bit.
Still have a mid range lean flat spot 3200-4000 rpm.
I’m going to continue with the 42 chokes, but may go down to 40’s.
I’m thinking of trying F2 tubes and maybe bumping the idles up to 58.
The lean flat spot is during the progression between closed throttle and the main jet circuit. So I’ll add a bit more fuel to smooth out progression between closed throttle and acceleration and for part throttle driving. And probably go back down to 185 fuel jets
Old H2S 04-16-2025 02:48 PM
I had to jump up to a F7 E tube to get it rich enough for the transition.
snbush67 04-16-2025 04:42 PM
Thanks, I have F7’s, I’ll try them too.
trond 04-22-2025 11:16 PM
apart from getting the carburettion right, what are your impressions so far. I have same cams on order and similar engine configuration and am interested in how the combination works. Did you check cranking compression numbers ? I have a 9.5CR and also a 10.5CR piston set and need to make a decision on which to use.
snbush67 04-23-2025 09:20 AM
I have not done a compression test yet. It’s on the to do list.
Impressions are good at 10.1, I’ve ran an advance curve of 30 to 7000 rpm’s on pump gas, single plugged. No issues.
The short header length (primary tubes are 17”) are great for top end, there’s plenty there but I want more bottom end snappy torque, to rip out of tight uphill corners in second gear. I’m probably going to go down to 40 chokes in the carburetor’s to get that, maybe sacrifice a bit of top end.
But there is gobs of power everywhere. Zero complaints.
Veeveessees 04-24-2025 01:53 AM
Nice project…
snbush67 05-16-2025 11:28 AM
Spun a rod bearing
I heard a tick and shut the motor down. Drained the oil and some metal came out.
Turns out the engine spun a bearing.
http://forums.pelicanparts.com/uploa...1747419322.jpg
So now I’m starting over. I’m happy knowing that I heard the ticking noise and shut it down before serious damage. It could have been a lot worse.
911 tweaks 05-16-2025 12:29 PM
good catch...!!
when you were building the engine, you obviously did not feel any resistance when by hand rotating the crank... so, defective part or what do you think happened...?
Hang in there Shane...
Good things come to those whom are good people & you are one of the good guys...
PeteKz 05-16-2025 12:59 PM
That sucks. I sure want to know what happened too.
snbush67 05-16-2025 02:06 PM
I’m really struggling to find fault, the bearing clearances were at 1.8 thousandths, the rods dropped effortlessly with their own weight but did have a slight drag.
The engine rotated smoothly.
Until after the ticking, that’s when I took out the spark plugs and did a leak down. Then I noticed a drag at 20 degrees before tdc for #1 and #4 so it was pretty clear it was at the crank.
When I removed the cylinders and rotated the engine #5 rod was hanging up.
I can’t believe that there was anything left behind in the oil lines but I guess that’s possible. Just don’t know.
The oil was clean, like new, and all the metal I found was right at the sump plate and a couple of small pieces on the sump screen.
Before the first start the oil pump was primed and then I cranked without spark several times for 10-15 seconds.
I think it’s likely the clearances may have been a little too tight and perhaps some debris.
The good news is that all cylinders had less than .5 leak down cold.
mikedsilva 05-16-2025 02:43 PM
I don't think 1.8 thou is the cause of the spun bearing.
Put the rod together and torque it and measure the big end again...
snbush67 05-16-2025 03:25 PM
Hi Mike. Nice to have you drop in.
http://forums.pelicanparts.com/uploa...1747434244.jpg
mikedsilva 05-16-2025 07:17 PM
ah.. no.. you need a bore gauge and micrometer to do this. Vernier calipers are not for this sort of measurement.
snbush67 05-16-2025 08:37 PM
Yes, I need a bore gauge. Tom (oldh2s) mentioned that to me that the rod end possibly wasn’t round.
That’s why I’m taking Williams recommendation and using new corrilo rods. Should have just did that the first time. I’ll also be bumping compression up and twin plugging.
http://forums.pelicanparts.com/uploa...1747452712.jpg
Old H2S 05-19-2025 01:13 PM
The ISO horror stories I could tell from 1 bad caliper out of 50 in my company..and 10 turned out to be counterfeit Mititoyo. Switched to Mahr when it absolutely had to repeat every time. I forced metrology QC every week and carried a ceramic gage block in my pocket to spot check every time I saw a chance, crushing peoples personal tools with a hammer to get it through peoples heads "zee vill do it ziss vay" I had to be the maintenance Nazi, the lost hours haunt me 25 years later.
dannobee 05-20-2025 10:08 AM
Did you replace the oil coolers?
http://forums.pelicanparts.com/uploa...1747760798.png
snbush67 05-24-2025 04:33 PM
Back at it!
After completing an autopsy, I’m resurrecting this build using all serviceable parts and replacing all non serviceable parts.
Today I was able to get all of the bottom halves cleaned out and checked the piston squirters. Oil pump, intermediate gears and chains, and all bearings are installed. Not a speck of metal was found.
http://forums.pelicanparts.com/uploa...1748129316.jpg
I replaced the crankshaft. Replaced the stock rods with Carrillo rods and bolts, and used standard bearings.
Bolts were tightened to .0065” stretch.
http://forums.pelicanparts.com/uploa...1748129379.jpg
Old H2S 05-26-2025 12:38 PM
Unfortunately the more engines you do the faster you get.I love my ultrasonic cleaner..
snbush67 05-26-2025 01:47 PM
Mine is not large enough for an engine. But it does make cleaning easier.
Got the case halves together today. Everything is spinning smoothly.
http://forums.pelicanparts.com/uploa...1748292212.jpg
snbush67 05-28-2025 07:30 PM
Deck heights and compression ratio
All deck heights are measured and adjusted to .040” (+/- .001”)
http://forums.pelicanparts.com/uploa...1748485374.jpg
http://forums.pelicanparts.com/uploa...1748485588.jpg
Jesse911 05-29-2025 03:57 AM
Nice work!
snbush67 05-29-2025 07:55 PM
Set up for cam timing tomorrow.
http://forums.pelicanparts.com/uploa...1748573638.jpg
snbush67 06-11-2025 09:30 PM
Timing is done. Lightweight flywheel is on. Lower valve covers are prepped.
http://forums.pelicanparts.com/uploa...1749702429.jpg
All I need now is a twin plug distributor….
mikedsilva 06-11-2025 11:28 PM
Interesting flywheel.. have not seen that one before.. where is it from?
proffighter 06-12-2025 05:30 AM
Looks similar to my Fidanza
snbush67 06-12-2025 06:23 PM
Fidanza. I’m not sure where it’s from, I picked it up locally from Brian at euro parts west. 4.4 lbs I think.
how do you like it? Any feedback on performance?Also did you locktite the bearing to the fly wheel or leave it free to spin?
I did had take a little material off the lower case bolt boss to clear the rivets.
http://forums.pelicanparts.com/uploa...1749777482.jpg
proffighter 06-13-2025 05:31 AM
I drove about 5'000km with, no issues since (400HP+). Use with KEP PP Stage1
It had no seat for bearing, made a aluminum adapter with press-seat for bearing.
No need to take-off material for mine.
Older pic, but shows enough
http://forums.pelicanparts.com/uploa...1749817805.jpg
snbush67 06-16-2025 09:40 AM
Another leak down.
Quick cold leak down, great numbers. All under 1%. Buttoning everything up, planning twin plug wire routings.
http://forums.pelicanparts.com/uploa...1750091907.jpg
http://forums.pelicanparts.com/uploa...1750091907.jpghttp://forums.pelicanparts.com/uploa...1750091907.jpg
snbush67 06-16-2025 09:49 AM
A small cut out on the chain box is required to make room for the lower plug hole.
http://forums.pelicanparts.com/uploa...1750092481.jpg
ToySnakePMC 06-17-2025 10:42 AM
Thanks for sharing all the build updates - It's very much appreciated. This will be a great motor when you fire it up.
snbush67 06-17-2025 06:03 PM
The tin is installed. I’m waiting for some twin plug pieces to arrive.
http://forums.pelicanparts.com/uploa...1750208452.jpg
snbush67 06-17-2025 06:06 PM
Thanks. I’m happy to share this build. I learn a lot from the forum participants.
Rosco_NZ 06-18-2025 12:57 AM
It’s always #2 / #5 big ends … cross drill the crank?
snbush67 06-18-2025 11:46 AM
Good question.
That was my first thought, but after much research and consultation I’ve decided not to.
The decision to not cross-drill wasn’t about cost, time, or availability. There is a lot more to discuss but in short, it was about getting the right amount of oil to the right places. The 993 pump is more than sufficient and I don’t want to sacrifice oil to the top half of the engine.
Rosco_NZ 06-18-2025 03:25 PM
993 pump will be ample, as you say about getting the oil to the right place, if rods were correctly prepped, a spun bearing points hard in a particular direction no? Assume you plastiguaged and measured the oil clearance?
If there is a weak spot in the very robust 3.0/3.2 case, it seems to be 3/5 big ends….
I agree with taking care of the valve train .. perhaps don’t install the smaller restrictors ..?? With 993 pump you have plenty oil to share around. My own theory is that is top end restrictors were a reaction the bottom end oiling issue. Which is better taken care of with cross drilling.
