-   -   Christmas Build, 3.2 Short Stroke, 10.1 CR (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1171904-christmas-build-3-2-short-stroke-10-1-cr.html)
snbush67 12-26-2024 11:24 AM
Christmas Build, 3.2 Short Stroke, 10.1 CR. — 10.4 CR and twin Plug
After some misinformation and insistence from Total seal rings that they gave me the right rings, I noticed scratches in my cylinders during my last build. Ian and I went to total seal with the rings and cylinders and pointed out that the oil control rings were over by .004” , they insisted they were right and accepted no responsibility for the damage to my cylinder’s. We deglazed the cylinders again and built with Goetze rings. The deglaze ended in a RA of 7 but we still had verticle scraping. After 15,000 miles the engine had unacceptable leak down.
Due to a less than desirable leak down, I'm going a fresh build.
Here goes.
Crank polished, rods balanced, bearings coated.
http://forums.pelicanparts.com/uploa...1735238824.jpg
993 Oil Pump.
Mahle Pistons and Cylinders sharp edges softened, washed and prepped.
Jeff Alton 12-26-2024 08:13 PM
How are the new ring gaps?
icarp 12-27-2024 06:40 AM
The oil rings from total seal were out of spec by .004" in the height measurement , undersized, so the rings were cocking in the cylinder , thus scraping and marring the cylinders.
The new MAHLE rings are much better than the last set I installed , last set I had was riddled with many burrs and sharp edges , leading to 4 hours of ring prep. The latest set is much better , all ring gaps came pre set to .0175" and very few burrs.
The pistons were standard no prep , valve pocket edges were razor sharp , so round off all edges .
Ian
fabracadabra 12-27-2024 07:14 AM
Ian, we spoke a few times in real life at the hill country ralleye, a real pleasure.
Hope you are doing well! The engine looks nice.
I was wondering if you have posted about the prep, you are doing sometime in the past?
If not, would you elaborate a bit on the process and materials used to prep?
I see a little 3 in 1 oil on the table and what looks like spongy sanding pads.
I think I also see some red assembly lube maybe and I notice a bead of 574 I think.
edit* I also notice nothing on the webbing as far as case sealant.
Hopefully soon I will be at a similar stage, and I would be interested in your thoughts on best practices.
Looking forward to seeing the rest of the build.
Chris
snbush67 12-27-2024 08:45 AM
Lots of prep so far, measuring everything two or three times making sure that everything is sterile and within spec.
The prep so far has involve polishing, the crank, balancing the rods, cleaning and checking in the case, checking the mating of all gears.
6 hours into piston and cylinders, the pistons get a razor blade scraped on all sharp edges, then smoothed with 220, finished with 600, only the edges are touched up. The pistons and cylinders are washed with a high concentration of dawn dishwashing liquid in super hot water and rinsed completely, then checked with a clean microfiber towel.
we’re installing rings now.
fabracadabra 12-27-2024 08:49 AM
Great info thanks y'all.
snbush67 12-27-2024 09:17 AM
Just the edges of the rings get light touch up to remove the sharp edges around the outer gap opening.
http://forums.pelicanparts.com/uploa...1735319811.jpg
snbush67 12-27-2024 09:41 AM
Rings installed.
Very nice, installed easily, they are perfect.
http://forums.pelicanparts.com/uploa...1735321257.jpg
mikedsilva 12-27-2024 10:40 AM
Not sure I'm understanding the above. Are you saying that deglazing removed the vertical marks but after you ran the Goetze rings and 15000 miles, the vertical scraping appeared again?
Or did you mean even with the deglazing, the vertical scraping was present before you put the Goetze rings in and did the 15000 miles...
I'm thinking it was the latter?
snbush67 12-27-2024 10:59 AM
http://forums.pelicanparts.com/uploa...1735323904.jpg
icarp 12-27-2024 11:10 AM
Mike, after the oil ring scratched the Nicasil liners we ran an 800 grit aluminum oxide Hone and we’re able to do a fairly good job but the scratches still remained. We put the engine together with the understanding it would be less than perfect
That’s not to say that we didn’t add a pinch of hope for the possible outcome
fabracadabra 12-27-2024 11:18 AM
Great close up of the ring ends thank you for sharing.
Old H2S 12-27-2024 01:25 PM
Shane, what did you run in the ultrasonic cleaner? Your parts look nice and clean.
I spray down with Dawn Power Desolver and run PineSol in the ultrasonic..
mikedsilva 12-27-2024 03:41 PM
Makes sense and I totally get why you did it.
Cheers
snbush67 12-27-2024 07:58 PM
I used a little dawn liquid.
Jeff Alton 12-28-2024 05:09 PM
This is getting a wee bit confusing.....
ICARP, are you and the OP (snbush67) working on the same motor?
What tool are you using to file the end gaps?
snbush67 12-28-2024 05:19 PM
Yes, ICARP is here with me.
All rings end gaps were perfect at .0175” so we didn’t file them further, we did lightly smooth the corners with 1000 grit sandpaper.
David Borden 12-28-2024 06:49 PM
... After 15,000 miles the engine had unacceptable leak down.
Can you share the results of the leak down test? Was the test performed warm or cold, and did you test once at the end or multiple times?
Curious if the hone may have caused premature wear of the rings or if it was the scratches or something else.
icarp 12-28-2024 07:30 PM
Jeff, yep same engine , softening the the rings with foam block coated with 1000 grit sanding face of black paper. See pic above
The rings must be checked for burrs and sharp edges , attend to all.
Leak down should be less than 1% in my book, they were 6%-8% leak down operating temp engine.
Scratches from the incorrect ring set from Total Seal was the cause of the poor sealing .
The scratches occurred from just turning the engine over by hand while setting the cam timing
The pic of the 574 sealant is missing some around the 8mm through bolt like the breather has
That line of sealant is enough to cause proper squish out around the whole case
I BELIEVE IN NOT ADDING ANY SEALANT ON THE MAIN BEARING BOSS FACE
ADDING SEALANT WILL DESTROY PROPER MAIN BEARING CLEARANCE
911 tweaks 12-29-2024 05:55 AM
Nice project…
Q any specs and or parts changing since you are back in there…?
You guys got this…!
This will be another eye opener build…!
Carry on…
