2.7L main bearings anywhere?
I need a set of standard size main bearings for a 2.7 (7R case out of a '77) and nobody seems to have any in stock. I tried calling Pelican, FCP Euro, Patrick Motorsports, EBS, Sierra Madre Collection, and some others places. They all said that they don't have any, they stopped carrying them, or their suppliers are all out.
That seems crazy. Anyone have leads on where to get a set?
Old 01-15-2025, 01:00 PM
PCA Member since 1988
Measure your old ones. If they are good, you do not need to replace them.
There have been out-of spec new bearings in the supply, so suppliers might have stopped carrying them until the quality issue gets fixed.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-15-2025, 02:21 PM
I have a set that was loaded but not run. I was going to use them in an early build but were tabbed for later 2.7.
PM for best response
Bruce
Old 01-15-2025, 02:25 PM
Pete, unfortunately no old ones to reuse. This is a totally fresh build from a donor case. Good to know on the quality issue though.
Bruce, awesome shooting you a PM.
Old 01-15-2025, 02:49 PM
It's a 914 ...
stownsen914's Avatar
ACL makes rod bearings for 2.7L. I wonder if they make main bearings.
Old 01-15-2025, 03:35 PM
I haven't heard of ACL so I did some quick digging. Unfortunately, it doesn't seem like they do. Bummer!
https://www.aclperformance.com.au/engine/Porsche/Porsche%20M%2044%202681cc%20Inline4%20SOHC%202v
Old 01-15-2025, 03:44 PM
no they dont make mains... I have approached them a few times, but they have no interest in widening their range.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-15-2025, 08:59 PM
Try rose passion, design 911 uk, or FVD Brombacher. They’re all in Europe, but I’ve had good luck finding parts that no one has in stock in the US. Shipping hasn’t been too bad.
Ward Komers
1984 944 Track Car - Sold
1968 912 Rust Bucket - Under Repair
1971 911T - Under Repair
2006 Carrera S - Sold
Old 01-15-2025, 09:37 PM
Thank you sir. I’ve seen Design 911 UK come up in search results but was a bit scared not knowing them and shipping overseas. Maybe they’ll have something.
Old 01-15-2025, 09:41 PM
I have bought from design 911 they are good guys.
1976 914
1986 951
Old 01-15-2025, 11:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We have them in stock.
We even have a plethora of weird sizes that are every difficult to find.
Example .50mm mains for 2.0-early 2.7 cases.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-16-2025, 06:08 AM
Thanks Henry. Will give you a call shortly.
Old 01-16-2025, 09:46 AM
