Banned
gasket sealer?
Hi
I was going to put together a 2.0 engine this week, I was wondering do you guy's use gasket sealer for the gaskets or just leave them dry?
I do have 574 sealer for the case and the cam housing, this will do on the gaskets too?
thanks
Dave
Old 07-05-2003, 08:51 PM
Author of "101 Projects"
Wayne 962's Avatar
See www.101projects.com - the 574 *will not* work on paper gaskets - it is designed only to seal metal-to-metal surfaces. The one area where I recommend that you use it on a gasket is on the cylinder head base gaskets, which are copper.
-Wayne
Old 07-06-2003, 06:49 PM
Banned
thanks ,
So.. I should leave the paper dry?
Old 07-06-2003, 08:30 PM
