Chain fence eating turbo
Turbo Carrera 3.2 (3.4) - losing hot idle oil pressure - which oil pump to use?
Before I do a full teardown for the 3rd time, I want to make sure I covered all the bases on my low oil pressure situation.
Out of the blue, my 3.4 started getting warmer, quicker than before and the oil pressure has been showing lower than before.
Normally, it would be around 1.0 bar at hot idle.
All of a sudden, it has been getting down to 1.0 bar right when the oil temp gauge shows the motor is fully warmed.
Then, it drops even lower until maybe 0.5 bar or less at hot (below or near 9 o'clock oil temps).
I am swapping out both the oil pressure relief and safety springs soon (as the parts arrive from the host) and replacing the external T-stat cartridge albeit I have boiled water tested it.
The internal T-stat and external T-stat cartridges seemed to work fine, but replacing the external as one day, one of the pipes was ice cold and motor was pretty warm already.
With that said, if the oil pump is dying and is the root of the low pressure and warmer running conditions (less flow for cooling), what budget friendly pump should I run with a redline of 6750 and a turbo?
This time I will crossdrill the crank.
TIA
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-18-2025, 10:22 AM
I’ve installed a couple of GT three pumps this year there is modifications to the case
The problems we have with the Carrera oil pump and losing number two or number five rod bearing
That problem doesn’t exist in the turbos, you might consider a turbo pump.
Bruce
Old 11-18-2025, 02:30 PM
Bruce
Thanks, Bruce.
Source for the pump?
Old 11-18-2025, 03:35 PM
PCA Member since 1988
Before you buy a new oil pump, or install new pressure springs, figure out why your oil pressure has suddenly decreased. Have you changed to a different, maybe lower viscosity oil? Are your OP sender and gauge operating correctly (put a direct reading analog gauge on the engine)? Did your operating RPM oil pressure decrease too? Is the oil pressure at operating RPM at least one bar per 1000 RPM? Did you reuse the old oil pump? If so, have you measured it for wear?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-18-2025, 04:04 PM
I did have 10W-40 at first and of course went back to 10W-50 when this all started.
Yes, the sender was dying after confirming with a mechanical gauge. Replaced and saw another half bar at hot idle, but even now, it’s going lower.
Never touched the pump between all the rebuilds/refresh
Old 11-18-2025, 07:02 PM
Oil pressure at hot idle (900-950 RPM, 9 oclock) is like 0.2-4 bar.
But, it will jump up quickly with a little RPM and still hit well over 3 bar by higher RPM at these temps.
Old 11-19-2025, 08:41 AM
If you have sufficient oil pressure at higher rpm’s, isit possible that one of more of your piston squirters are stuck open at idle?
Old 11-30-2025, 06:05 PM
It's a 914 ...
stownsen914's Avatar
Interesting point about a squirter sticking open. Squirters do fail.
People talk a lot about the cam oil restrictors to improve idle oil pressure. No specific advice to offer, but it might be worth looking into if you're not using them.
Old 11-30-2025, 07:15 PM
Hi
As a Porsche oil pump, (in good order) is a constant displacement pump, oil pressure is a function of RPM & oil viscosity and how much oil is escaping/leaking from the system, through relief valves, bearing clearances, piston squirters and tensioner bleeds etc.
If you fit a new oil pump with the same size pressure section, it may well not fix your low pressure at idle problem.
Suggest you focus on determining where the excess system oil leakage is occurring.
Are you using the the oil restrictors that screw into the cam boxes ?
Has the oil relief valve on the top of one of the chain tensioners failed/popped off ?
Hope this helps.
Cheers
Old 12-01-2025, 09:34 AM
TIA
I'm no expert as everyone knows, but will share a similar (not identical) experience.
An early engine I had was showing lower than desirable pressure at idle. But when revving above idle, it had normal pressure according to the gauge.. ie, 1 Bar for every 1000 rpm..
However I pulled it apart and found that the main tunnels in the case were oversize quite a lot. Which basically meant I had several 'small oil leaks'... the case was resized, NEW BEARINGS WERE INSTALLED, and that engine now shows 1.5B at hot idle.
I don't think that rebuilding it was totally necessary but I wanted to learn more about these engines.
Not saying you have the same issue, (it might be rods also) and I hope this is not your issue.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 12-02-2025, 11:07 AM
I will definitely look during teardown.
Old 12-02-2025, 11:16 AM
Originally Posted by Magyar Kiwi View Post
Hi
Hope this helps.
Cheers
You know, I am pretty sure I have the restrictor style adapters, but I need to check again.
I need to reword the beginning. I did not tear 3 times in a row because of a low oil pressure situation, was simply stating I am going into this motor for the 3rd time in 18 years and never touched the oil pump.
It is simply wearing out if I had to guess.
Old 12-02-2025, 11:18 AM
The bearings snapped into place during replacement this last time, the case journals should be fine.
The crank journals have been nominal the other 2 times.
Old 12-02-2025, 11:20 AM
