-   -   Twin Plug Heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1172884-twin-plug-heads.html)
Racerbvd 01-18-2025 05:10 PM
Twin Plug Heads
Who is the “GoToo” shop to have heads machined for twin plug?
The guy who use to do our work has retired.
http://forums.pelicanparts.com/uploa...1737248868.jpg
mepstein 01-18-2025 06:33 PM
Anyone who rebuilds heads should be able to add the extra spark plug hole.
brighton911 01-19-2025 04:24 AM
Cgarr (Craig Garrret) does fine work and his rates are reasonable too.
Dpmulvan 01-19-2025 05:10 AM
+1 for Craig
'78 SC 01-19-2025 05:49 AM
+1 for Craig.
I built a twin-plug engine and encountered these other issues:
  • decide on 12mm or 14mm spark plug holes
  • bore exhaust valve covers for lower plugs
  • open up RR chain box for #4 lower plug
  • modify LF engine tin for #3 lower plug
I went with 12mm lower spark plug holes after confirming I could get suitable spark plugs for uppers and lowers. I sent Craig the valve covers to be bored. The chain box was easily modified with a Dremel tool and the engine tin required some hammering.
Turbo_pro 01-19-2025 06:45 AM
If timing is important you might give Supertec a call. I believe they have a two week turn-around on head work. All machine work done in house.
A friend just got a performance 2.7 built in less than 30 days after it hit the top of the list.
snbush67 01-19-2025 09:15 AM
772.286.1660
bill@xtremecylinderheads.com
3471 SW Palm City School Ave
Palm City, FL 34990
Racerbvd 01-19-2025 10:04 AM
Thanks for the info.
icarp 01-19-2025 04:52 PM
Byron, I have had Bill's do 5 sets of 911 heads in the last 5 months . The customer service and product is first rate , what I am used to from the old days . The tech is also top notch , total research .
Ian
Jeff Alton 01-23-2025 07:17 PM
Our local guy we have been using for over 20 years, always perfect. But it is a long way for you to send heads, though with our dollar being minimal, may make sense.....
mikedsilva 01-24-2025 01:54 AM
Maybe I should send mine there too !
mepstein 01-24-2025 04:25 AM
The exchange is good but shipping to CA is usually fairly pricey.
1973914 01-24-2025 05:23 AM
Bill @ extreme built my heads. Great shop and in your state
flat6pilot 01-24-2025 11:11 AM
Craig Garrett
+1 for Craig (garrett@iserv.net) He did a set for me last year.
http://forums.pelicanparts.com/uploa...1737745828.jpg
bavaria911 01-24-2025 01:57 PM
I used Anchor Atlantic here on the East/North East coast.
https://anchoratlantic.net
Turbo_pro 01-24-2025 03:20 PM
These are the heads Supertec did for my SS 3.2
http://forums.pelicanparts.com/uploa...1737760727.jpg
I think Supertec is one of the few Porsche engine builders that do their own machine work in house.
http://forums.pelicanparts.com/uploa...1737760866.jpg
Jeff Alton 01-24-2025 06:34 PM
Yes, you are 100% correct.
We can do a shipment to 98230 and we import them across the border. However, there are many great options inside the US, some mentioned in this thread.
Cheers
mepstein 01-24-2025 06:59 PM
Cheers
I agree. We use a top notch machine shop to rebuild our heads but one of my employees has a mill and could do the twin plug in house if he wanted to. It’s not rocket science to drill a hole on an angle and tap it for a spark plug.
Jeff Alton 01-24-2025 07:55 PM
^^^^^ exactly! Despite being reviered by many, like you said, it is not rocket science. Just simple machine work.
Cheers
trials935 01-25-2025 07:59 AM
Don at EBS does a great job. I've had about 5 sets done, no issues.
Soko121 01-25-2025 07:54 PM
What are the pro’s to Twin Plug Heads ? What sort of performance changes ? Any cons ? Do they work for 3.0 / 3.2 / or 3.4 ?
rngreenejr 01-26-2025 08:58 AM
@ Soko121 - there are other threads on this forum debating the benefits. I am no expert but basically twin plugs allow more complete combustion, allow higher compression engine on pump gas. You can also go coil on plug and avoid distributors and have a clean highly efficient set-up. There are a lot of pros and the biggest con is cost. Typically going twin plug would go along with higher compression pistons, ITBs, cams, porting heads. I'm in the middle of a twin plug 3.0 to 3.2SS conversion. Not cheap but definitely improved performance. TLDR: better performance and compression at the expense of cost.
winders 01-26-2025 03:01 PM
Coil on Plug (CoP) works great on single plug setups...most CoP setups are single plug.
chrismorse 01-31-2025 04:51 PM
Craig Garrett did a great job on my 2.8
I think it is important to support our parts makers and machinist aficionados that do good work for our old cars.
Craig has good/prompt communication, excellent machine work, packaging and Good pricing.
He sourced better quality guides, did a good valve job/head resurfacing and twin plug work for my dad's old 74.
For sure, there are a lot of good people out there, and Craig is one of them.
He took my 32mm intakes to 37.
Use him again in a heart beat.
chris
fabracadabra 01-31-2025 05:56 PM
FWIW I also had a great experience with Craig at G2.
I echo everything above.
Chris in TX
al lkosmal 02-04-2025 08:43 AM
Craig Garrett (Cgarr)........excellent work, great turn time, pricing, etc.
