Twin Plug Heads
Who is the “GoToo” shop to have heads machined for twin plug?
The guy who use to do our work has retired.
Old 01-18-2025, 05:10 PM
The 9 Store
Anyone who rebuilds heads should be able to add the extra spark plug hole.
All used parts sold as is.
Old 01-18-2025, 06:33 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Cgarr (Craig Garrret) does fine work and his rates are reasonable too.
1986 Targa Guards Red
2021 MT09 SP
Old 01-19-2025, 04:24 AM
+1 for Craig
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 01-19-2025, 05:10 AM
I am my 911's PO
'78 SC's Avatar
+1 for Craig.
I built a twin-plug engine and encountered these other issues:
  • decide on 12mm or 14mm spark plug holes
  • bore exhaust valve covers for lower plugs
  • open up RR chain box for #4 lower plug
  • modify LF engine tin for #3 lower plug
I went with 12mm lower spark plug holes after confirming I could get suitable spark plugs for uppers and lowers. I sent Craig the valve covers to be bored. The chain box was easily modified with a Dremel tool and the engine tin required some hammering.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 01-19-2025, 05:49 AM
Constitutional Liberal
Turbo_pro's Avatar
If timing is important you might give Supertec a call. I believe they have a two week turn-around on head work. All machine work done in house.
A friend just got a performance 2.7 built in less than 30 days after it hit the top of the list.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 01-19-2025, 06:45 AM
bill@xtremecylinderheads.com
3471 SW Palm City School Ave
Palm City, FL 34990
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-19-2025, 09:15 AM
Thanks for the info.
Old 01-19-2025, 10:04 AM
Byron, I have had Bill's do 5 sets of 911 heads in the last 5 months . The customer service and product is first rate , what I am used to from the old days . The tech is also top notch , total research .
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 01-19-2025, 04:52 PM
Jeff Alton's Avatar
Our local guy we have been using for over 20 years, always perfect. But it is a long way for you to send heads, though with our dollar being minimal, may make sense.....
www.turn3autosport.com
Old 01-23-2025, 07:17 PM
Maybe I should send mine there too !
Always learning.
www.aircooledporsches.com.au
Old 01-24-2025, 01:54 AM
The 9 Store
The exchange is good but shipping to CA is usually fairly pricey.
Old 01-24-2025, 04:25 AM
Bill @ extreme built my heads. Great shop and in your state
Old 01-24-2025, 05:23 AM
flat6pilot's Avatar
Craig Garrett
+1 for Craig (garrett@iserv.net) He did a set for me last year.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 01-24-2025, 11:11 AM
bavaria911's Avatar
I used Anchor Atlantic here on the East/North East coast.
https://anchoratlantic.net
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 01-24-2025, 01:57 PM
Turbo_pro's Avatar
These are the heads Supertec did for my SS 3.2
I think Supertec is one of the few Porsche engine builders that do their own machine work in house.
Jim
― Thomas Sowell
Old 01-24-2025, 03:20 PM
Jeff Alton's Avatar
Yes, you are 100% correct.
We can do a shipment to 98230 and we import them across the border. However, there are many great options inside the US, some mentioned in this thread.
Cheers
Old 01-24-2025, 06:34 PM
The 9 Store
Cheers
I agree. We use a top notch machine shop to rebuild our heads but one of my employees has a mill and could do the twin plug in house if he wanted to. It’s not rocket science to drill a hole on an angle and tap it for a spark plug.
Old 01-24-2025, 06:59 PM
Jeff Alton's Avatar
^^^^^ exactly! Despite being reviered by many, like you said, it is not rocket science. Just simple machine work.
Cheers
Old 01-24-2025, 07:55 PM
Don at EBS does a great job. I've had about 5 sets done, no issues.
Old 01-25-2025, 07:59 AM
