2.4l Cylinder head CE ring/head gasket ID
Does anyone have a 2.4l CE ring laying around that they could check the ID on? I'm planning a 2.5l build with 86mm cylinders/pistons and I'm trying figure out if 2.7l heads will seal to 2.4l cylinders (overbored to 2.5l) with the chamfer on the 2.7 head combustion chamber. It looks like the OD on the chamfer is 89.2mm so if the CE ring ID is less than than it may not seal. Thanks in advance for the help!
-Josh
Old 01-16-2025, 03:02 PM
Nobody?
Old 01-17-2025, 12:22 PM
PCA Member since 1988
Send a PM to Henry Schmidt. He should know.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-17-2025, 03:34 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The issue is not whether the CE ring will seal but with the late 2.7 head the chamfer will create a lip where the combustion will encounter a lip at the top of the cylinder.
Chmfer larger than the bore.
The Chamfer on the late 2.7 head is generally about 88mm (depending on who machined it last. Not all machine work/machinists are equal.
The early 2.7 (74, 2.7 RS) heads have no chamfer at the sealing surface and they are about 86mm.
The inside diameter of the CE groove in the AA 86 is 91mm.
That's all I have from memory. Others may have closer numbers..
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-17-2025, 05:35 PM
Thanks SO much Henry! You are the first one that could shed some light on this. So it looks like early 2.7 heads would be perfect without additional matching being necessary, otherwise it is best to use 2.4 heads and have them chamfered. The heads I'm looking at have a 5-74 date but are chamfered, I'll have to have the seller measure them to see what the OD on the chamfer is. I'm assuming the attached pic are the later 2.7 heads?
Old 01-17-2025, 06:15 PM
As an FYI to everyone, 5-74 date 2.7s heads are indeed "late" 2.7 heads so they are a no-go for 86mm jugs unfortunately. The OD on the chamfer measured 88.81mm.
Old 01-19-2025, 07:23 AM
kwikt 911's Avatar
Old 01-19-2025, 10:18 AM
Originally Posted by kwikt 911 View Post
Thanks!
Old 01-19-2025, 11:01 AM
The important measurement is the groove cut in the cylinder not the ID of the CE ring. The CE ring dimensions can vary from manufacturer to manufacturer.
You were a gentleman to take the time to offer your measurement.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 01-20-2025, 06:58 AM
Cheers
Interesting, I would have thought CE rings would have been machined to pretty exacting dimensions. The groove ID is what I was angling for, just assumed it would be more likely someone would have a CE ring easily accessible. With that said, it seems like John Walker also had a good point relating to 2.7 heads on 84/86mm bores...with an 89mm-ish head chamfer OD and a 91mm CE groove ID, that only leaves 1mm of inner sealing surface. I'm far from an expert, but I've read the inner sealing surface is what is most responsible for head sealing (CE ring is just for fluid), and I'd guess only 1mm of metal to metal seal is not sufficient, especially in higher compression builds. Thoughts?
And thank you both...gentlemen all around
Old 01-20-2025, 08:10 AM
kwikt 911's Avatar
Old 01-20-2025, 05:14 PM
kwikt 911's Avatar
Old 01-20-2025, 05:18 PM
