-   -   2.7 motor low oil pressure (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1173570-2-7-motor-low-oil-pressure.html)
tailwind22 02-05-2025 08:50 AM
I have a twin plug hot rod motor in my 914 GT tribute. Less than 10,000 miles since rebuild and correct gauge and sender combo. Struggles to maintain one bar per 1000 rpm when warm. Recent leakdown showed 2% throughout the cylinders. It has a larger front oil cooler. Any thought that the extra cooler and oil line capacity might be too much for the oil pump? Trying to understand what is going on.
pemz0r 02-05-2025 04:40 PM
What's the current oil weight you are using, and is this first time you noticed this after 10k miles or did just start?
john walker's workshop 02-06-2025 07:33 AM
What's the pressure @ 5K?
tailwind22 02-06-2025 07:54 AM
PO had the rebuild done and pressure has been low since my ownership a couple of years ago. Engine is running VR1 dino 20/50.
3 bar
Rosco_NZ 02-06-2025 08:53 AM
44 psi hot doesn’t sound too bad. What oil pump? Updated pil pressure relief valves? Bypass mod?
stownsen914 02-06-2025 09:07 AM
44 psi sounds a bit low, even for an early motor.
What are the oil temps? Higher temps could be a cause of lower pressure.
john walker's workshop 02-06-2025 05:45 PM
You could install the cam tower oil hose restrictor fittings to get a bit more pressure. Not a big fan, but porsche designed them....
tailwind22 02-07-2025 08:56 AM
Is the 2.7 known for lower oil pressure readings?
Henry Schmidt 02-07-2025 09:40 AM
We've been moderating cam oil feed since the mid 80s. When Porsche came out with theirs in the 965 (91-92 Turbo) we investigated their version. I believe the 965 cam feed fittings are a little too restrictive.
We still make our own fitting with a slightly larger oil passage and when we encounter the Porsche version we bore them out (slightly).
The modification is a good one if you consider what your goals are.
