-   -   Carrera 3.0 engine rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1174267-carrera-3-0-engine-rebuild.html)
mikedsilva 08-01-2025 12:13 AM
i never use old chains.
mepstein 08-01-2025 04:30 AM
Right! Chains and plastic chain guides are consumables. If sprockets are getting pointy, they get replaced.
Jesse911 08-14-2025 01:49 AM
I will be buying a new oil pump. I narrowed it down to two options:
3.2 pump
993 pump (aluminium)
The 993 pump being bigger should provide more oil. Apart from the shorter shaft do I need to make any other changes?
Jesse911 09-01-2025 03:52 AM
Some updates:
Checked big and small end on the connecting rods. Bought this tool online and had a friendn print it with his 3D printer. Works really well.
http://forums.pelicanparts.com/uploa...1756727412.jpg
Went with the 993 oil pump, fits the Carrera 3.0 (930/02) case without mods!
My KMS ITBs
Now onto setting end gaps for the pistons rings.
