-   -   Carrera 3.0 engine rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1174267-carrera-3-0-engine-rebuild.html)
Jesse911 02-22-2025 02:23 AM
After my 3 year project of backdating my '76 911 I will now do the engine. During the backdate process I did a regular service because the condition of the engine was unknown (bought the car running but that was it). The engine is a 930/02 Carrera 3.0.
http://forums.pelicanparts.com/uploa...1740223024.jpg
The engine pulled strong and took me all the ways to the Alps last September. However as the engine had sit for maybe 10 years + some of the gaskets were failing. As the looks of the engine were also a bit less compared to the rest of the car I want to rebuild it and add EFI with ITBS.
The ITB/EFI part I already figured out now just the engine :).
Taken the engine apart and will get the case, crank, heads and rods to a machine shop this week. They will check all measurements. Preliminary measurements by me show that the crank, rods and case are all STD size and no obvious signs of problems.
Somewhere in the history of this car the nikasil cylinders have been replaced by alusil cylinders.. And piston no6 was put in 180 degrees wrong..
I will have my cylinders checked if they can be plated with nikasil. If not I will have to get new cylinders. I'm considering the 3.1 set made by Supertech (Henry) but I will have to check the costs of shipping and taxes to Europe.
If I stay with 95mm I will go for JE or Wossner pistons with 10 - 10.5-1 CR. We got good quality fuel here so I can stay single plug.
What I would like to have some advise on. What camshaft would be good for 95% street driving and keeping in mind I will have ITBs.
Also does my case or crank (6 bolt) need any mods when getting more HP from this engine.
If you guys are interested I can make this a complete rebuild topic. BTW I will be building this engine myself.
Bill Verburg 02-22-2025 09:04 AM
Put a '73-74 RS cam in it same as was used in the 3.0RS
Jesse911 02-22-2025 04:35 PM
Thanks Bill will look into that.
I see a popular cam here is the DC40. Would that work?
Close to me we have Cat Cams which also have some cams for the 911. How can I compare the cams? The duration is the same as the DC40 but it has a different lobe angle and slightly less lift.
http://www.catcams.com/products/camshafts/datasheet.aspx?ENGINE_id=252&CAMSETUP_id=1034&Lang uage=english
Rosco_NZ 02-23-2025 01:58 AM
I think the mod-S version of the S cam works well. My 2.7RS spec engine seems to love it … webcam 464/465
Bill Verburg 02-23-2025 03:34 PM
DC-4- mod S, sure similar to the S/RS but w/ more lift, be sure of piston clearance
These are every nice street cams for 3.0 to 3.2 as long as you have ITBs or carbs
Richey 02-23-2025 05:52 PM
You will be disappointed with the DC40's , you do not need the more torque and HP from 3000 to 5000 that the modS's provide with a 3.0 liter engine . the engine displacement provides enough . I don't even like the DC40's in a 2.2 liter , the engine signs off after 5500 rpm instead of the S cam's added push to 7000 , but this is a subjective opinion .
mikedsilva 02-24-2025 01:20 AM
For what it's worth, I ran Mod S in my 3.0 carrera... single plug.. 10.2:1 compression.
Ran fantastic. Itbs, efi.
Great torque from 3500 all the way to 7k
Richey 02-24-2025 06:48 PM
As I said , it becomes subjective , "ran fantastic " is subjective . I believe it would have been more fun with true S cams .
Rosco_NZ 02-25-2025 05:51 PM
Mod-S provides both Tq & HP gains in most displacements, very surprised a 2.2 would 'sign off' after 5000 rpms .. not my experience in 2.7. Strong 2.2S compression and exhaust should make it work well.
Jesse911 03-02-2025 01:15 AM
Thanks guys.
I talked to a local cam grinder here in Europe as the shipping/import taxes make USA camshafts really expensive and went with his advice.
http://forums.pelicanparts.com/uploa...1740910470.png
For pistons. I see JE pistons now also have a 10:1 piston in 4032 which can be run with a tighter clearance and should be a better match with the Mahle cylinders.
Any pro's or con's besides that instead of going for their 2618 pistons?
stownsen914 03-02-2025 05:04 AM
One note - the wider lobe centers of that Cat grind might be aimed at a single throttle body application. I believe you mentioned running ITBs, which opens the door for more aggressive cam grinds.
Henry Schmidt 03-02-2025 07:28 AM
This is a silly comment. The Mod "S" cam has proven to be far superior to the factory "S" in almost every aspect. If you found limited performance above 5K in a 2.2 engine you did something wrong.
Dima designed the Mod"S" cam to overcome Porsche's propensity towards high duration low lift cams in their search to reduce cam/rocker parasitic loss.
Henry Schmidt 03-02-2025 07:34 AM
Agreed. That CAT cam profile listed above would perform better with a 106 LC.
Given your compression ratio and piston preferences, you should have no issues with a narrower lobe center as far as piston to valve clearance.
One caveat: A new build like this always requires careful attention to build tolerances.
Neil Harvey 03-02-2025 08:49 AM
Originally Posted by Jesse911 (Post 12420820)
Thanks guys.
If I can add my 2C's worth.
Go with the local Cam company as they will be able to answer any questions you have after any use, in case it may require some changes. Lift and duration numbers along with LCA's are 3 of the factors that produce changes in performance. There are a lot more factors in a lobe design that contribute to the performance.
Going with known cam designs is always a good idea when you want simple choices. Unfortunately, many of the historic proven designs are copies on top of copies and not close to the original.
When I decided to get back into the Cam supply business I decided that new engineered designs would be our focus. So all new designs are A symmetrical using all modern camshaft engineering we have learned over the past years. I saw no point in offering the same as everyone else.
The internet is full of opinions, me too, but we do not know what you have, how you drive etc. Go with what you have as a starting point and then ask your supplier for any recommendations.
When choosing the Piston, make sure you provide the Piston maker with the Valve drops and ask the Cam supplier for the Valve lifts each side of TDC from 20°. This way you can be sure the valve pockets and clearances will be ok.
dedyplay 03-02-2025 11:25 AM
Great job , look forward to completion..
Richey 03-02-2025 06:59 PM
I replaced the Mod S camshafts in the 2.2 engine with stock S cams , definitely more zip after 5500 to 7000 rpm which I wanted , so nothing was done wrong , but less torque / horsepower between 3000 and 5000 ,
so the choice becomes subjective as to what a person likes .
Rosco_NZ 03-03-2025 01:05 AM
I’d suggest less between 5500 & 7000 too. It just appears to come in harder when there’s so little there before …
Rosco_NZ 03-03-2025 01:06 AM
Not the general consensus. I’d suggest less between 5500 & 7000 too. It just appears to come in harder when there’s relatively little there before …
Henry Schmidt 03-03-2025 07:04 AM
Perhaps tuning for different cams was required....if all you did was swap cams.
These are your projects and as the builder you can choose any combination of parts you choose.
Like others have said, perhaps seat of the pants can be deceptive.
We've built these early engines (both road and track) and because of this long term commitment to air-cooled 911 engines we've had the opportunity to dyno all mannor of combinations.
As far as 911S vs Mos "S" the performance is objective not subjective.
Some where in our files, we have dyno sheets that confirm this performance enhancement.
A little story: years ago we had a 914/6 customer that could afford to experiment.
We built him a long stroke 2.5 and a short stroke 2.5. The dyno showed they made the same peak horse power [right around 265hp] but did it differently.
After a weekend of testing, the customer was sure the short stroke engine was quicker. (Seat of the pants)
What surprised the driver was the long stroke motor trimmed the lap times by almost 2 seconds.
Of course there are a plethora of factors that affect performance but seat of the pants is deceptive.
Richey 03-03-2025 07:27 PM
As I said , what a person likes , not necessarily the fastest , I like the original 2.2S personality , but interesting story about the 2.5 liter engines . I think Porsche also experimented with 2.5's in the ST and used the short stroke version , but a different time and a different track .
Henry Schmidt 03-04-2025 08:23 AM
The story is not about performance/horse power. It is about the mindset that created an inaccurate assessment of performance.
Actually. Porsche experimented with short and long stroke 2.5 liter engines and the results were as follows.
70-71 2.5l short stroke 87.5 x 66 250hp @ 7800 188 f/lb@ 6200
70-71 2.5l long stroke 86.7 X 70.4 270 hp @ 8000 191.6 f/lb @ 6200
Of course in the development of the long stroke engine they discovered the inherent problem with the 70.4 crank at high RPM. The crank would develop a high RPM harmonic that would spit the flywheel off. The cure for that issue was a redesigned crank used in the later 2.8 and 3.0 RSR engines.
Richey 03-04-2025 06:56 PM
According to the above specifications , the short stroke was a 2.38 liter engine and the long stroke was 2.49 liters , so not really
a simular comparison .
Rosco_NZ 03-05-2025 08:43 AM
No, there were long and short stroke 2.5’s. 2.3’s all SS.
Jesse911 03-06-2025 01:38 AM
Thanks guys for all the replies.
I went for the Cat Cams as this camgrinder is very local to me and I read on this forum of someone from Denmark who had the same cam in his 2.7 with ITBS and he had 270hp at the crank. If I can get to similar number i would be very happy!
I'm also using the valve springs from CAT Cams which are made by PAC springs in the USA.
Just ordered a lot of tools from Stomski Racing and my case, crank and heads are at the machine shop to have them checked and rebuild, balance the crankshaft with pulley and flywheel.
Jesse911 03-13-2025 02:45 PM
Lovely tools by Stomski have arrived today. Not bad one week after ordering in the USA to Europe.
http://forums.pelicanparts.com/uploa...1741905916.jpg
mikedsilva 03-13-2025 07:44 PM
yep, I use them and love them.
Rosco_NZ 03-18-2025 10:12 AM
The piston pin C clip tool from Stomski is a very good thing!!
Jesse911 03-25-2025 08:16 AM
My reground cams for Cat Cams arrived together with their springs. Now waiting for the machine shop.
http://forums.pelicanparts.com/uploa...1742919394.jpg
Jesse911 05-04-2025 04:38 AM
Some more parts.
Supertec head stud kit
http://forums.pelicanparts.com/uploa...1746362297.jpg
ECUMaster Black ecu and sensors
ToySnakePMC 05-04-2025 06:29 AM
Nice pieces & parts. Thx for keeping this thread going. This will be fun to watch. Best of luck. Patrick
gsxrken 05-04-2025 12:14 PM
You will love the Stomski bits and they will take the likelihood of an error on your part down to near-zero. Excellent investment!
snbush67 05-29-2025 01:47 PM
I use this dynamic compression ratio calculator, I hope it’s of use to you,
https://uempistons.com/p-27-compression-ratio-calculator
Black 993 05-31-2025 06:10 PM
What ITB's are you using?
mikedsilva 06-01-2025 02:29 AM
Originally Posted by Jesse911 (Post 12458579)
Some more parts.
Glad to see another Emu Black ecu join the group. Amazing value.
Jesse911 06-02-2025 11:26 PM
Thanks!
Still deciding between Jenvey ITB or a local dutch company KMS.
https://kms.vankronenburg.nl/products/throttle-body-kits/porsche/throttle-body-kit-porsche-911-optional-airhorns-45mm
Thanks Mike. The value of the EMU black does seem to be excellent!
Jesse911 06-07-2025 03:49 AM
In the meantime I have received my DP motorsport amber fanshroud. Also had some parts Cerakoted.
My 3.1 supertec piston/cylinderset will arrive this week :cool:
http://forums.pelicanparts.com/uploa...1749296966.jpg
Jesse911 06-12-2025 12:16 AM
And the 3.1 pistons and cylinders received. Now waiting for the engine shop to have my heads, crank, case ready.
http://forums.pelicanparts.com/uploa...1749716175.jpg
Jesse911 07-31-2025 05:02 PM
So picked up all the parts from the machinist. Crank was balanced and checked, heads rebuild, case cleaned and inspected, rods checked and new ARP bolts, all new bearings.
I also balanced the the connecting rods to within 0.1 gram. Had a friend 3d print a jig to balance the rods. Worked great!
http://forums.pelicanparts.com/uploa...1754010095.jpg
http://forums.pelicanparts.com/uploa...1754010110.jpg
I'm now looking into all the sprockets for the timing chains. Does anyone know if the Sebro sprockets are any good? Or am I better of using the old sprockets with new chains?
mikedsilva 07-31-2025 05:07 PM
Looking good. Which version crank pulley and trigger wheel is that?
When it comes to sprockets, I tend to re use them if they are not showing obvious signs of wear. You can go crazy and repace EVERYTHING but if the chains were aligned previously and nothing solid went through the engine, then they should be good to reuse.
If I come across one which shows signs of wear from the chains rubbing or if it suffered a tensioner failure, then they are all likely being replaced.
Jesse911 07-31-2025 06:01 PM
Crank pulley is from Adapt Motorsport.
Thanks Mike I will have a good look at my sprockets than. Unfortunately I misplaced my chains so I don't know which one was left and which one right side. If the sprockets look to be in good condition some new chains would be ok?
