Cam Thrust cover failure.
I have a 1984 3.3 Turbo engine which has a pretty significant oil leak coming from behind the right chain housing. I believed the issue was a leaking gasket or o-ring from the cam/chain housing. upon investigation, I found that there was a significant crack all around the cam thrust cover (930.105.196.00). I will be replacing this cover, the O-ring and gasket. My question however is root cause. The only thing I can think of is if there is excessive play in cam that caused the housing failure. Has anyone else encountered this issue? Is there anything else I should be looking for? Bellow is a shot of the crack.
Thanks for any input. Keith |
abit off center
Make sure the cam sprocket is on the right way too.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
HI Keith
I take it you have the engine out, I would take the rest of the rockers out of the damaged side of the engine and make sure the cam turns free, as it looks like the cam has been run into the back of the cam box tight, the cover/seal has been fitted and then everything tightened up , putting strain on the case cover by pulling the tight cam back into position, or the heads have been built up and the rocker gear fitted, then all the head,cam box, rockers assembly fitted to the rest of the engine, with the tension on the cam from the rockers fitted dry, also the cam may be tight in the cambox as it could not be checked with the head/cam all built up, it would take some pull and strain on the seal plate to get things lined up again. just my 10 peneth regards mike |
hi ..is there any history we do not know about? Like the engine has been worked on recently?
I would definitively suggest to check parallel alignment of timing chain sprockets... Ivan |
Check your sprocket wear. It may indicate there is an incorrect number of shims under the cam drive sprocket.
There shouldn't be any real Thrust on the cam. But maybe, there was too many shims and the chain exerted a force pushing the cam into the head The crack looks pretty big. Someone use a big hammer to get the woodruff key out?! |
as i said above you have to do this...either you or someone had to switch left shims to right and vise versa ..what is the history?
Ivan Last edited by proporsche; 12-12-2017 at 10:28 AM.. |
Pelican Parts Vendor
Hi guys, URO Parts recently developed replacement Cam Thrust Plate 930 105 196 00, and invites two or three experienced engine builders in the US to test-fit a couple in return for providing feedback for our engineers. Since the plates aren't very expensive, we could include some extra items to help compensate you for your time.
Just drop us a PM if interested! Tags: 93010519600, 90110519601, 901 105 196 01
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 |
