Sorry to hear about your troubles, there's a lot of good advice above. If it's a true 12:1, that's definitely a lot of compression even running 110. Your dynamic will be slightly higher with the milder cam too. I second the mentions that 30 degrees is a LOT of timing for twin-plug. I run 24 in my 11.5:1 3.0 twin plug race engine (built to HSR rules). It did make a little more power on the chassis dyno with 26-27, but I wanted to be conservative especially since I'm running carbs. The pics are of the plugs in an engine that ran lean, didn't even run it a full lap. After that I installed an AEM afr meter. With sunoco purple (110), the O2 sensor only lasts ~5 race weekends.
PCA Member since 1988
Ugly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's a 914 ...
Yep that motor was really unhappy
Damn SV - Flame thrower. How long did that run and it wasn't misfiring like crazy? I have never seen plugs that bad even on Turbos that went kapputt.
R lane You didn't share which A/F meter you were using? Also, given what you have seen a new sensor is on order no matter what at this time even if a high quality device is on hand. In our experience the Bosch Lambda 4.9s last at least 50 hrs, often 80-100 w leaded fuel. Never buy from a cheapie internet source(goes for everything on these engines) , loads of Chinese knock offs out there. Also check your rod bearings are okay, or you will be right back here with even greater damage...and how did ring land gaps on top ring measure? Lastly, trusting your piston sheet is a mistake, actually CC your dome displacement volume, sometimes they are quite off from intended design as I shared. Good luck Kevin GAS Motorsport
Upland, CA |
Hey Kevin, yeah it was a bad day. Rolling race start and down the front straight at summit point. It was down power, so after turn 1 i limped it back to the pits but the damage had been done. Amazingly those plugs were still firing. The HVC coil is a heck of a coil.
Burned p/c
burned p/c
31 degrees ignition advance at full throttle for a twin plug motor is way too advanced. Doesn't matter if you're running 110 octane, or your dynamic or static compression is as low as 10.0:1. You're causing the peak pressure of combustion to hit your pistons as it's still rising up in the cylinder, hammering on the pistons, cylinders, crank, bearings, etc. Imagine when you press down on a bicycle pedal for max torque. You want to press down in at 1:00 position of rotation, not at 11:30 - you'll hammer your knees. If you use a dyno, you can advance your timing until power levels and back down from there for margin, assuming fuel octane is not your limitation. When you advance timing on the dyno, when it levels, and goes down after that, you went too far. The suggested timing numbers given by others here are a good place to start.
svcetiquette, in the picture of your head it looks like there is a crack from the intake seat over to the spark plug hole.
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 04-02-2025 at 04:38 AM.. |
An article on pre ignition vs detonation: Detonation, Knocking & etc.
Racer
My last race engine (120HP per liter at the crank) had 12.5:1 compression using 110 and 112 leaded race gas. I ran no where near advance 30 degrees of timing...
Oh, NTK oxygen sensors handled leaded fuel better than Bosch oxygen sensors...
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Installed a knock sensor kit but the controller appears defective. Fellow sent another by USPS and they apparently have lost it. Have a dyno appointment on Tues morning, so will make some runs without the benefit of knock control or being able to see when PI or det is occuring. I plan to set my timing at 24* and be armed with a stethoscope. Not sure for what I will be listening but will continue to raise the timing a bit at a time until HP has reached its terminous. I am thinking for my setup, 26* might be my limit. Prescribed procedures On how to know where to set ignition to avoid melt down here would be greatly appreciated. Thanks, Bob
Start at 20 deg, then keep advancing until the power drops off, then retard 2 degrees from there.
Installed a J&S knock sensor system and took it to the dyno yesterday. At 20* we had 267HP, added 2 degrees and had 287HP. 2 more degrees and 291HP. At the top of that run the low end of the LED bar flickered briefly. The LED bar has low, medium and high light intensity indicating the severity of the knock and that timing has been pulled back. Off to the track to see if we are safe. Bob
It's a 914 ...
Nice result. So you ended up at 22 degrees?
My last run was at 24*. I think I am ok with that, maybe replace think with hope, but will I think bring it back to 22* as the extra 2* netted me but 4 additional HP. An interesting aside to backing off timing is that as you reduce that number, the piston finds itself further up the barrell when ignition happens. Meaning that it has less distance to travel when pushing against the force that ignition has just initiated. Bob
That’s a LOT different than the previous 30 degrees !!
Tested at a track night, 3 sessions. Engine felt good and no issues. 4 days at Summit Point and no engine issues. Have just pulled the valve covers to check valve lash and head torque, all good. Am at 22* timing and engine has good power. Don;t know if it is an improvement over the previous engine with ''my'' heads at 28* timing, but it felt good and it stayed together. Thanks again for all the counsel. Bob
| Tags |
| bob |
